Boost on gsr and some other issues
Old Jun 22, 2005 | 09:01 PM
95turbogsr's Avatar
Default Boost on gsr and some other issues
Hey i need your guys expert opinion becuase im stuck in Alaska were everyone owns a damn truck or sti i bought a turbo for my car and im building the kit myself im also rebuilding my motor with forged pistons and rods and new top but i was wondering can i run 10psi with stock injectors and a stock ecu? also my comp ratio now is 10:1 would dropping it down to 9:1 or 8.8:1 be any better? manifold i heard rev hard is pretty good but wats better tubular? or cast iron? any help would be greatly appreciated becuase you are the only guys i have to ask
Old Jun 24, 2005 | 04:09 PM
ChronicGreenDC2's Avatar
Default Re: Boost on gsr and some other issues (95turbogsr)
I think you should of split these questions on a few different theads, but I'll make this short and sweet:
9:1, Tube
Just my 2cent
Old Jun 24, 2005 | 07:46 PM
pv2dickman's Avatar
10psi.. don't think you want to run stock injectors
Old Jun 24, 2005 | 07:56 PM
95turbogsr's Avatar
Default Re: Boost on gsr and some other issues (pv2dickman)
Yea i was thinking 440 or 550 i think im going to get most of my stuff from rev hard i would have split my ? more but i can only get 5 posts and day for the next two weeks but thanks for the info im going to with 9.7:1 comp ration with a hondata s200 im still stuck on the manifold, and am i going to need the map sensor bypass even with a hondata?
Old Jun 24, 2005 | 09:07 PM
AllensBlkGSRSleeper's Avatar
this is the set up on my turbo gsr, im running 550cc injectors, and only 9.5 psi on a tuned ecu, u gotta tune ur ecu. im running uberdata, some what like hondata but cheaper. got new je pistons which are 9.0:1 ratio, if u wanna run lower ratio then u will need a b16 head, with that head u'll run a ratio of i think 8.2:1--8.5:1. and as far as manifold, i have a cast iron from rev hard, pretty descent ut i want a equal length tho but other than that the cast iron is good
Old Jun 25, 2005 | 03:00 AM
95turbogsr's Avatar
Default Re: (AllensBlkGSRSleeper)
rev hard looks liks good stuff i heard good things about them i just wasnt sure about cast iron or tubular , i cant get the car dynoed and im goind with 9.7:1 comp with forged pistons and rods with a built head dule springs and stuff im gettin a honda but i dont have a dyno avaible that i know of so the comp is going to load a base map for me based on the specs i send them and im going to get the s200
Old Jun 25, 2005 | 11:26 AM
Default Re: (95turbogsr)
The tube will flow a lot better. I have a tube log type manifold just cuz I wanted to keep my AC. If the AC is not an issue, go w/ an equal length tube.
I also have the Hondata S100 and I can't say enough good things about it. No bypass valves, regulators, or FMU = no problems
Old Jun 25, 2005 | 11:29 AM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbogsr &raquo;</TD></TR><TR><TD CLASS="quote">rev hard looks liks good stuff i heard good things about them i just wasnt sure about cast iron or tubular , i cant get the car dynoed and im goind with 9.7:1 comp with forged pistons and rods with a built head dule springs and stuff im gettin a honda but i dont have a dyno avaible that i know of so the comp is going to load a base map for me based on the specs i send them and im going to get the s200</TD></TR></TABLE>
Jesus, if you don't have a dyno available and probably **** all for knowledgeable honda tuners don't run high compression! You want the biggest safety margin possible.
J-Spot
Mar 12, 2008 11:56 PM
VTEC=GOD
Jul 27, 2007 05:02 AM
j87w
Jun 22, 2005 06:21 PM
LSVtechnologytur...
Jan 20, 2005 09:03 PM
nstalr1072
Jun 3, 2002 05:48 PM
