Seem slow for 7psi?
Old Jun 22, 2005 | 10:33 PM
eRACING's Avatar
Default Seem slow for 7psi?
We went to the track this past weekend with my brothers car. He just put on the turbo kit a few weeks ago so we haven't had the chance to tune the car. Obviously the car will get a little faster once we get it all tuned up correctly, though I would think the car would be running faster than it is still being untuned. The car ran a best of 13.8 @ 100mph on 22x8x15 slicks which wouldn't normally bring up any concerns if it were done on normal street tires... (ran 14.7 before N/A on street tires) The car was being launched at 8K with 12psi in the tires... car seemed to feel boggish off the line, etc.. which will, or should be solved once tuned...
Anyhow, my question is, doesn't 13.8 @ 100 MPH seem a little slow for this particular setup? I'd think it'd be closer to low 13s flat on slicks and at least be over 100MPH. Thoughts?? What are others running for times on a stock 7psi B16 setup on average??
Car Setup:
94 Coupe w/full interior
JDM b16a Block/Tranny (internally stock)
ITR b18c5 Head+IM (internally stock)
Rev Hard Stage 2C Kit (T3/T04E beleive 60 trim) at 7psi of boost
Walbro 255 Intank Pump
Hondata S200B
RC 440's
Greddy Evo Exhaust w/o cat
Few Video's (notice even launching at 8K the car falls on its face or hesitates a bit):
Right Click; Save As:
http://www.sirrommotorsports.c...8.avi
http://www.sirrommotorsports.c...5.avi
http://www.sirrommotorsports.c...4.avi
http://www.sirrommotorsports.c...3.avi
Old Jun 22, 2005 | 11:56 PM
eRACING's Avatar
Default Re: Seem slow for 7psi? (erics99si)
before bed bump
Old Jun 23, 2005 | 05:11 AM
frago's Avatar
I would say its right on... although I can't watch the video's because I am at work.
Old Jun 23, 2005 | 05:21 AM
deftones0817's Avatar
what was your 60 foot time? You need to give us your timeslip so we can look at that...i cant watch video either im at work.
Old Jun 23, 2005 | 06:00 AM
lkailburn's Avatar
sounds normal especially for untuned. and what about the driver? driver obviously will make a HUGE difference in times
Old Jun 23, 2005 | 08:17 AM
salt's Avatar
Default Re: (frago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frago &raquo;</TD></TR><TR><TD CLASS="quote">I would say its right on... although I can't watch the video's because I am at work.</TD></TR></TABLE>
sounds right, if a b16 puts 140 to the wheels, and .5 bar add 50% power that puts it about 210HP. And if a lot of timing is pulled in the basmap it may make less. Turn up the boost and get it tuned!
Old Jun 23, 2005 | 09:04 AM
crispydee's Avatar
Default Re: (salt)
Your launcing at 8k on a base map with stock interals? you must have money to burn!
Old Jun 23, 2005 | 09:22 AM
ITSME4G63's Avatar
its your launch, loook at your mph that pretty high for a 13.8
Old Jun 23, 2005 | 12:22 PM
eRACING's Avatar
Default Re: (ITSME4G63)
I'll have to talk to my brother about the exact time slip... as for the the 60's I know he averaged 2.0's with 1.9xx being the best. Not the best sixty ft's but with the bogging outta the hole he couldn't keep the power up. He's a decent driver... before the turbo, he ran 14.7 on streets full interior, big stereo etc..
Old Jun 23, 2005 | 12:48 PM
Sketch_hs's Avatar
i ran 1/4 at 104 mph, t3/t4 5.8 psi open DP UBERDATA
Old Jun 23, 2005 | 01:25 PM
gsrcivic1996's Avatar
thats pretty good for a b16 untuned.... I have a GSR in my EK coupe with lots of bolt ons and skunk 2 ecu for now, I ran 13.9 at 99mph N/A
Old Jun 23, 2005 | 02:17 PM
YiNYaNg's Avatar
Default Re: (crispydee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">Your launcing at 8k on a base map with stock interals? you must have money to burn!
Pushing your motor untuned
Old Jun 23, 2005 | 02:49 PM
eRACING's Avatar
Default Re: (gsrcivic1996)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic1996 &raquo;</TD></TR><TR><TD CLASS="quote">thats pretty good for a b16 untuned.... I have a GSR in my EK coupe with lots of bolt ons and skunk 2 ecu for now, I ran 13.9 at 99mph N/A</TD></TR></TABLE>
That is a good time for "N/A"... this is a boosted setup..
Old Jun 23, 2005 | 07:21 PM
CoreyR's Avatar
Default Re: (erics99si)
my friends got almost your same setup
94 coupe full interior
stock JDM B16
stock clutch
t3/t4 60-1
2 1/4 DP with a 2 1/4 dump under back seat
AEBS intake mani
RC 440's w/ walbro 255
barely tuned on uberdata, only AFR's tuned with conservative timing retard (.8* per PSI)
on beat *** street tires (195/60/15) with 20 psi in the tires he ran the following
6.5 psi - 13.9@104
8 psi - 13.4@107
10 psi 13.5@109
the car had faster runs in it but we ran out of time.
Old Jun 23, 2005 | 09:21 PM
Muckman's Avatar
Moderator in Chief
So let me get this straight, its slow....... and untuned? Slow.... and UNtuned. Nope I don't see any correlation there...
Old Jun 23, 2005 | 11:50 PM
eRACING's Avatar
Default Re: (Muckman)
Thats what we're finding out so far
Any other smart *** brain busting comments?
Old Jun 24, 2005 | 12:05 AM
Tony the Tiger's Avatar
Looks like you were hitting the factory fuel cut. That will most likely prevent the turbo from building boost off the line. I can see that once you get going, it picks up pretty nicely.
Before doing anything else, get it tuned with some form of engine management like everyone says. Depending on what system you go for, you should set it up with a 2-step/ignition retard to help build boost off the line
Old Jun 24, 2005 | 10:44 AM
eRACING's Avatar
Default Re: (Tony the Tiger)
He has the Hondata S200B, which brings me to a question concerning the launch limiter feature with you hondata users... When he's sitting at the staging line waiting for the tree to light up, flooring the pedal should raise RPM's up to the decired set limit but also start building boost just sitting stationary correct? If so, how much boost do you S200B users build before launch.. What RPM do most of you guys launch around?
Old Jun 24, 2005 | 03:40 PM
usdmcivic94's Avatar
Whats your setup?
Old Jun 24, 2005 | 04:02 PM
eRACING's Avatar
Default Re: (usdmcivic94)
setup's listed at the top of the thread
Old Jun 24, 2005 | 08:54 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erics99si &raquo;</TD></TR><TR><TD CLASS="quote">He has the Hondata S200B, which brings me to a question concerning the launch limiter feature with you hondata users... When he's sitting at the staging line waiting for the tree to light up, flooring the pedal should raise RPM's up to the decired set limit but also start building boost just sitting stationary correct? If so, how much boost do you S200B users build before launch.. What RPM do most of you guys launch around?</TD></TR></TABLE>
your not really gonna build boost without a load on the motor especially with only a 1.6L and a big turbo like a 60 trim.
Old Jun 24, 2005 | 09:36 PM
Default Re: (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">
your not really gonna build boost without a load on the motor especially with only a 1.6L and a big turbo like a 60 trim.</TD></TR></TABLE>
Not sure if the S200B has 2-step retard function, but if it does, it will retard ignition timing/add fuel to create enough exhaust energy to build boost off the line.
Old Jun 24, 2005 | 10:43 PM
Humble Performance's Avatar
I put a drag kit on my friends Si back in 2000' and on 5 psi we ran 13.3@103 mph open exhaust.
eRACING
Jun 24, 2005 08:08 PM
toxicrx
Aug 26, 2003 08:23 PM
servion
Aug 18, 2003 05:09 PM
ALLMOTOR18
Jul 22, 2003 10:38 PM
DIRep972
Dec 2, 2002 10:37 AM
