injector size
Old Jun 24, 2005 | 11:32 AM
95turbogsr's Avatar
Default injector size
Hey im not sure what size injectors to run i got a hondats s200 coming a t04e turbo and im going to run about 10psi i was thinking 440's but would the 550's be better? and of course the fuel pump and an upgraded motor as well
Old Jun 24, 2005 | 11:33 AM
crxnj's Avatar
Default Re: injector size (95turbogsr)
what's your hp goal.?
Old Jun 24, 2005 | 01:18 PM
s2kdre's Avatar
Default Re: injector size (Mr.speaker)
if u got hondata you can use 880 cc bigger now than later
Old Jun 24, 2005 | 03:41 PM
YiNYaNg's Avatar
Here is a quick equation.
???cc injectors /5x4=???hp <===your injector will be @ 100% duty cycle
Assuming your fuel pressure is at 45psi. Increase it and you can run more hp.
550cc/5x4=440hp ==>100% duty cycle
Just a reference equation!
The next time if you want to have a idea of someone's max hp use this equation. If they even know how many cc injectors they have.
Old Jun 24, 2005 | 07:54 PM
95turbogsr's Avatar
Default Re: injector size (H-T)
well i want to run about 300 here in alaska but i want get more when i leave here i was thinking 440 or 550?
Old Jun 24, 2005 | 08:32 PM
RMS's Avatar
RMS
a quick target equation for a honda turbo app with a very rich tune (11:1) is:
inj cc/2=whp
600cc/2=300whp dyno jet whp...
this leave a lot of room for leaning the tune down. H-t gave you the best case senerio, this is the worst case
Old Jun 24, 2005 | 08:35 PM
TheShodan's Avatar
Moderator
550cc can work fine for over 400whp.
Old Jun 25, 2005 | 02:57 AM
95turbogsr's Avatar
Default Re: (TheShodan)
thanks everyone for the help i think 550 it is
Old Jun 25, 2005 | 03:28 AM
boostedcivicsir's Avatar
Mr. Badwrench
http://www.rceng.com/technical.htm#WORKSHEET
thats the calculator i use.
Old Jun 25, 2005 | 09:27 PM
RMS's Avatar
RMS
rc's cal'or is very close based on what we see using a dynojet AND 91oct PUMP GAS.
52#injs (550cc) at 95% duty cycle (way higher than recommended) and with a bsfc of .55 (pretty much the besssssst case senerio for a turbo pump-gas engine) nets about 360 bhp. with a drivetrain loss of 16% (again, bessssst case senerio) you should see about 310WHP... hmmm.
redo the calc with more realistic numbers (85%DC, .65bsfc, and 18% drivetrain loss) and you get 272WHP... my quick cal'r says 275whp. pretty darn close maybe not what people WANT to hear, but who are we to argue with physics?
edit: using a rising rate fuel pressure regulator won't even get you to 400whp with pump gas and 550cc injectors according to rc and math...
Y2K Si FBP
May 23, 2011 05:08 AM
Charlie Moua
Oct 28, 2009 11:09 AM
Project_DX
16
Jul 30, 2006 08:09 AM
s2kkid
Jul 13, 2005 04:59 AM
sparq
Jul 30, 2003 01:57 PM
