OEM headgasket and boost
Old Jun 22, 2005 | 01:59 PM
19sec beast's Avatar
Default OEM headgasket and boost
How far can I run with the stock headgasket? I just replaced it about 10,000 miles ago.
I'm about to put have a built head installed on my car. Should I replace it or will it be fine?
I'll be going for 375-400whp.
Old Jun 22, 2005 | 02:05 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: OEM headgasket and boost (19sec beast)
some people swear by cometic, and inline pro, i have a cometic only because i have an 84mm bore b16. proper tuning is the key. i think a stock headgasket should hold it. but i have no experiences above 300 whp to back that up. my last engine held up to 280 whp. from there and above i cant say.
Old Jun 22, 2005 | 03:23 PM
s2kdre's Avatar
Default Re: OEM headgasket and boost (boostedcivicsir)
oem is good up to 35psi
Old Jun 22, 2005 | 05:36 PM
USDM 4G VTEC's Avatar
the headgaskets are not the issue when building a motor
its the fact that bolts and studs stretch and make the contact between the head and the block loose the torque wich will cause separation and when that happens the gasket its exposed and then it burns or brakes (blown headgasket)
Old Jun 23, 2005 | 10:25 AM
Default Re: OEM headgasket and boost (USDM 4G VTEC)
Hooray for my ARP head studs then.
rick_rabies
Apr 17, 2009 09:09 AM
rick_rabies
Apr 15, 2009 12:49 PM
EG2Driver
Jul 15, 2007 10:19 PM
skiracer8148
Mar 16, 2007 09:56 AM
ek_kid
Mar 22, 2006 09:47 PM
