*************please help me, i have a problem***********
Okay, i have a brand new built LS block with a used B16 head....... Basically LS/Vtec..............I was driving yesterday and i started to see my idle going really low. Like around 600 rpm....... Then later on, when i was driving, i put it in neutral, it died out on me! I would start it up and it would be fine again. Then i started to hear ticking noise, assuming valves cause it cant be rod knock cause i have a brand new built block, i have oil, and rod knock makes a really loud knocking noise........Anyway, i kept driving cause i had to go to work and i would try to accelerate, it wouldn't go, it would like take forever just to go up 1 mph.......... Then i slapped it back to neautral and it died out on me......... I cant' figure out the problem guys! I check the timing to see if i skipped a tooth because i needed to change my timing belt, but the cam gears teeth were aligned...........Please help me honda-tech members because i spent a lot of money on that motor! Please give me some answers, thank you!
Re: *************please help me, i have a problem*********** (H.A.R.T B18C1EG6)
Sounds like whoever adjusted your valves left the adjuster loose and they came out of adjustment. Loss of compression can cause you to lose your idle. Just a thought. Do a compression test.
Everytime I put my car in neutral it was dying on me also. I have a fresh built ls/vtec turbo. I guess I was having the same problem but my car would still get up and go though. I couldnt figure it out and it just stopped automatically.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 »</TD></TR><TR><TD CLASS="quote">Okay, i have a brand new built LS block with a used B16 head....... Basically LS/Vtec..............I was driving yesterday and i started to see my idle going really low. Like around 600 rpm....... Then later on, when i was driving, i put it in neutral, it died out on me! I would start it up and it would be fine again. Then i started to hear ticking noise, assuming valves cause it cant be rod knock cause i have a brand new built block, i have oil, and rod knock makes a really loud knocking noise........Anyway, i kept driving cause i had to go to work and i would try to accelerate, it wouldn't go, it would like take forever just to go up 1 mph.......... Then i slapped it back to neautral and it died out on me......... I cant' figure out the problem guys! I check the timing to see if i skipped a tooth because i needed to change my timing belt, but the cam gears teeth were aligned...........Please help me honda-tech members because i spent a lot of money on that motor! Please give me some answers, thank you!</TD></TR></TABLE>
theres not much we can do with just that
get a compression test done on all the cylinders
do a leakdown test done
make sure the engine timing is right (not by just looking at the cam gears)
drain the oil ,and pass a magnet thru the oil see if theres any metal
put a oil pressure gauge and monitor it
H.A.R.T B18C1EG6
06-27-2005 03:41 PM
H.A.R.T B18C1EG6
06-26-2005 09:41 PM
H.A.R.T B18C1EG6
06-26-2005 09:38 PM
