Max Power on 93 (experts needed)
Old Jun 29, 2005 | 12:12 PM
fanta!'s Avatar
Default Max Power on 93 (experts needed)
Whats the most recomended Whp number is safe for 93 octane?
b-series?
h-series?
Old Jun 29, 2005 | 01:45 PM
Kwuaymaikrup's Avatar
Default Re: Max Power on 93 (father)
I *think* Tony1 posted a while back that the most he likes to tune for on pump is in the 100hp per cylinder range. I made 402 on pump and a very conservative tune and low boost. I have seen a lot higher numbers but the tune was probrably more aggressive and they were running like 18psi. It can be done but I wouldn't feel comfortable going that high with my setup.
-Ryan
Old Jun 29, 2005 | 03:14 PM
fanta!'s Avatar
Default Re: Max Power on 93 (Kwuaymaikrup)
would it/can it be higher if its a built motor?
Old Jun 29, 2005 | 03:51 PM
Boostage's Avatar
https://honda-tech.com/zerothread?id=1069470 519 on pump gas
https://honda-tech.com/zerothread?id=803640 470 hp on pump gas
Im sure 600 on pump gas is possible if the compression is low enough
Old Jun 29, 2005 | 03:53 PM
D@nnY's Avatar
I made 402 also on pump gas with my old setup... Its just alot more unstable and all 93 octane is not equal. Its very common for a gas station to give you a tank of bad gas and potentially destroy a high hp motor.
I know mase made 513 on pump before..see what he thinks
Old Jun 29, 2005 | 03:57 PM
b16sedan's Avatar
Default Re: Max Power on 93 (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1069470 519 on pump gas
Im sure 600 on pump gas is possible if the compression is low enough</TD></TR></TABLE>
There's a difference between possible and realistic.
Pump gas to me means we're talking street trim, so you can drive it for quite a while on the street with no problems. At 500 WHP on pump gas you are a half a bad tank of gas away from good bye motor, and I don't think it's practical for a real street car.
I think 400-450 is a safe range, and even that is getting to the point of being completely worthless on the street.
Old Jun 29, 2005 | 04:04 PM
D@nnY's Avatar
not to mention the wideband isnt going to tell you if you have bad gas...it will read rich and melt it self to death from pre ignion
Old Jun 29, 2005 | 04:05 PM
fanta!'s Avatar
Default Re: Max Power on 93 (b16sedan)
i know all the #'s that are possible but like everyone else said i dont want to get a bad tank of gas and the set up go down the drain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan &raquo;</TD></TR><TR><TD CLASS="quote">
I think 400-450 is a safe range, and even that is getting to the point of being completely worthless on the street.</TD></TR></TABLE>
exactly.. does it matter about the whp # or more about how agressive the tune is? how effient are h series motors?
Old Jun 29, 2005 | 04:06 PM
Boostage's Avatar
Why do u want more than 400hp on pump gas tho?
Old Jun 29, 2005 | 04:15 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by father &raquo;</TD></TR><TR><TD CLASS="quote">exactly.. does it matter about the whp # or more about how agressive the tune is? how effient are h series motors?</TD></TR></TABLE>
It's a combination of both. WHP dictates how agressive your tune can be, and how agressive your tune can be dictates WHP. At some point pump gas simply will not be able to control detonation, and I think you're coming up on it FAST at 500 WHP.
Old Jun 29, 2005 | 04:20 PM
fanta!'s Avatar
It's a combination of both. WHP dictates how agressive your tune can be, and how agressive your tune can be dictates WHP. At some point pump gas simply will not be able to control detonation, and I think you're coming up on it FAST at 500 WHP.</TD></TR></TABLE>
Old Jun 29, 2005 | 05:09 PM
Haleiwa-Brando's Avatar
This is true to a point, but let me throw in another fact into the mix: How well the gas is going to work is relative to how efficient your engine uses that engergy. Tuning is not the only factor here. Bottom line is: The internals will dictate on how efficient the engine will work as a whole. If two engines have the same exact setup except say; one engine has a stock head and the other has a fully built head, it's quite obvious that under the same exact tuning condition on the same gas, the engine with the built head will make more power because it has to work far far less to suck in and expel air/gases.
Old Jun 29, 2005 | 05:16 PM
b16sedan's Avatar
Default Re: Max Power on 93 (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
This is true to a point, but let me throw in another fact into the mix: How well the gas is going to work is relative to how efficient your engine uses that engergy. Tuning is not the only factor here. Bottom line is: The internals will dictate on how efficient the engine will work as a whole. If two engines have the same exact setup except say; one engine has a stock head and the other has a fully built head, it's quite obvious that under the same exact tuning condition on the same gas, the engine with the built head will make more power because it has to work far far less to suck in and expel air/gases.</TD></TR></TABLE>
And like I said, at 500 WHP you're coming up on those limits, no matter how efficient your head is. Boosted Hybrid commented about how much a ported head helped on pump gas, and said "10-20 WHP at best", so I don't think it's some huge factor where on a stock B16 head you might squeeze out 450, but on a race ported ITR head you can make 600 no problem.
Old Jun 30, 2005 | 10:29 AM
fanta!'s Avatar
Old Jun 30, 2005 | 11:18 AM
onefstek's Avatar
I made 496 whp and 320 wtq on 92 octane pump gas.
boosting about 17-19 psi on a stock sleaves gsr motor.
Old Jun 30, 2005 | 12:07 PM
RyanEJ8's Avatar
You could get a bad tank of gas and blow up a 200hp motor.
Old Jul 6, 2005 | 08:13 AM
fanta!'s Avatar
Default Re: Max Power on 93 (RyanCivic2000)
boosted crx-r
Aug 29, 2009 05:12 PM
garage16.ca
Feb 23, 2009 01:49 PM
Thepanda
May 10, 2006 10:39 AM
integlspwr2k
Aug 2, 2005 07:15 PM
Flamenco-T
Sep 4, 2002 04:20 AM
