when i should be reading boost?
Old Jun 30, 2005 | 07:18 AM
civiclx97's Avatar
Default when i should be reading boost?
i just installed my drag gen III turbo kit in 97 lx with b16 and im having problems determinign whether i have a boost leak or not...ive heard a bunch of numbers about this kit about when it reaches full boost and the most commonly used rpm seemed to be a round 4500....i read about 5 psi around 4500 but only when i am like flooring it or almost wot....i could be cruising on the highway at 4000 rpm at very little throttle and be reading like 8 in HG of vaccuum....does that sound right or should i alwaya be reading boost at certain rpm's or is it only when i push the throttle fast enough to create boost?
Old Jun 30, 2005 | 07:25 AM
BlackCRX's Avatar
boost is load dependant, so if you are cruising there is almost no load on the motor which means no spool
Old Jun 30, 2005 | 08:52 AM
Dunc's Avatar
BCICAN
Default Re: (BlackCRX)
^^^exactly, which is also why you could be cruising at 8000rpms and have no boost at all.
Old Jun 30, 2005 | 10:23 AM
civiclx97's Avatar
Default Re: (Dunc)
ok thanx just making sure i dont have a leak
Accord94DX
Jul 22, 2003 02:06 PM
incognitoracerr
Apr 23, 2003 06:52 AM
b18c1-ek
Mar 5, 2002 01:17 AM
