Catback/muffler recommendation
Old Jun 30, 2005 | 08:44 PM
elpiar's Avatar
Default Catback/muffler recommendation
Few questions: I'm going 7-10 psi boost on my GSR on stock motor with stock cat and exhaust
1. Which is more worth the cost? high-flow cat or upgrade exhaust (catback/muffler)
2. I want a muffler which provide better flow, but I don't want the ricey loud muffler, I want it as close to stock noise as possible, this is a daily driver and I want elegance with real power, not showoff.
Suggestions?
Old Jun 30, 2005 | 09:07 PM
red cx's Avatar
Default Re: Catback/muffler recommendation (elpiar)
the oval magnaflow is a good choice.
Old Jul 1, 2005 | 07:32 AM
elpiar's Avatar
any other opinion? answers to my questions?
Old Jul 1, 2005 | 07:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
if you are keeping the boost at 7 psi. with the cat, any 2.5 piping system will work. i have always gone with either 2.5" or 3" with a free flowing muffler. mine is loud as hell, 3" with an Apexi N1,but i think a 2.5 custom with a magna flow will work for you.
Old Jul 4, 2005 | 06:56 AM
elpiar's Avatar
Default Re: Catback/muffler recommendation (boostedcivicsir)
ANyone knows a high flow muffler with stock-like sounds?
Old Jul 4, 2005 | 07:08 AM
95cxh22a's Avatar
^^ would alsolike to know
im thinking about a dynomax bullet in 3in, with a magnaflow out back.
Old Jul 4, 2005 | 08:10 AM
VI Boost's Avatar
Default Re: Catback/muffler recommendation (95cxh22a)
2.5" with a Magnaflow is a good setup, the magnaflow will give you a nice deep low tone that wont be too loud or annoying. If not that I hear the RSR EXMAG is the quietest catback system out and it sounds almost like stock.
Old Jul 4, 2005 | 08:27 AM
tilt's Avatar
Your closest bet would be hytech or mugen. They use a dual pass muffler which imo is the best compromise for stock-like noise vs flow. The s2000 uses the same idea but i have no idea how well it flows.
If dual pass is out of your budget id go with a straight through like magnaflow or es oval.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">ANyone knows a high flow muffler with stock-like sounds?</TD></TR></TABLE>
Old Jul 4, 2005 | 10:06 AM
urbansi's Avatar
Default Re: Catback/muffler recommendation (tilt)
RSR for sure, very quiet and looks good too.
Old Jul 6, 2005 | 08:08 AM
elpiar's Avatar
Default Re: Catback/muffler recommendation (urbansi)
any other recommendation? RSR is way too expensive
Old Jul 6, 2005 | 10:41 AM
Blazin Civic's Avatar
Get a kteller 3 inch or if you area baller get a thermal R&D 3 inch.
Old Jul 6, 2005 | 11:32 AM
BlueSi2k's Avatar
Default Re: Catback/muffler recommendation (Blazin Civic)
I use a kteller 3 inch system with a resonator and I recently switched from a magnaflow straight through to a dynomax super turbo I think (chambered). The 3 inch with magnaflow sounded good and wasn't THAT loud but the dynomax quieted it down quite a bit and still flows really well since it has 3 inch internal flow tubes. I can barley hear it cruising on the highway and it just sounds mean when you open it up.
BoboyRS
Feb 28, 2009 11:35 AM
mushroom281
11
Jun 30, 2007 12:50 AM
Metal Honda G
Sep 14, 2004 01:23 AM
roadawg
Sep 24, 2003 03:44 PM
ScottEK
10
Jan 23, 2003 05:47 PM
