How to tune timing with EGT
Old Jun 28, 2005 | 06:33 PM
elpiar's Avatar
Default How to tune timing with EGT
or...can you really?
If I choose to install EGT gauge as a monitoring device, what should I look for? If hottest EGT is at 14.7:1 stoich AFR, then what good is it?
How will too much retard or advance timing affect EGT?
Old Jun 28, 2005 | 06:37 PM
93turbo16's Avatar
Too much retard will usually yiled higher EGTs.
Old Jun 28, 2005 | 07:58 PM
mamaboy's Avatar
Default Re: How to tune timing with EGT (elpiar)
the extra load created by advancing and/or retarding will yield you higher egt's
Old Jun 28, 2005 | 08:00 PM
adseguy's Avatar
Default Re: How to tune timing with EGT (mamaboy)
From what I've read on other sites and hear, it really shouldn't be used as a tuning tool, but just to keep in check that you are doing the tuning correctly and nothing is out of control. You don't wanna aim for much with an EGT guage, but when you are adjusting timing make sure the EGT's don't go past a certain point....get it? Always good to have though
Old Jun 28, 2005 | 09:49 PM
lodo1's Avatar
Default Re: How to tune timing with EGT (adseguy)
egt is gonna more of a safety tool, like adseguy said. you wanna make sure you dont melt pistons and that type of stuff!!
Old Jun 28, 2005 | 10:16 PM
uglyasscivic's Avatar
Default Re: How to tune timing with EGT (tdocrx)
The only time you would really tune EGT's is if you have one for each cyilnder and you have individual ignition trims.
Old Jun 28, 2005 | 10:17 PM
itrhatchling's Avatar
So let me get this straight in my head. Advancing and retaring timing moves the power power band left and right one the dyno graph. But when you are tunning you need to watch your EGT so that you don;t cook anything in the motor. At what temp would you start to cook internals.
Old Jun 29, 2005 | 12:20 AM
Mase's Avatar
its really easy.....
you dont.
Old Jun 29, 2005 | 12:25 AM
Vsm Hatch's Avatar
Default Re: How to tune timing with EGT (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">its really easy.....
you dont.</TD></TR></TABLE>
LOLZ!!!! I second that
Old Jun 29, 2005 | 04:37 AM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdocrx &raquo;</TD></TR><TR><TD CLASS="quote">egt is gonna more of a safety tool, like adseguy said. you wanna make sure you dont melt pistons and that type of stuff!!</TD></TR></TABLE>
What's a temperature range that is a warning sign for B18C1 engine, suppose I install the EGT at the manifold runner?
How much estimated temperature drop if I put it 6 inch after the turbo?
Old Jun 29, 2005 | 12:26 PM
elpiar's Avatar
need opinion
thatcivic96
Engine Management and Tuning
Jan 27, 2011 05:00 PM
tianporn
22
Jul 16, 2006 09:32 PM
LostCRX
May 12, 2004 07:15 AM
Sinner
Oct 1, 2003 04:21 PM
DC2R714
Sep 22, 2003 12:21 PM
