fuel pressure suggestions
Old Jun 29, 2005 | 02:07 PM
elusive123's Avatar
Default fuel pressure suggestions
i have a crv-tec turbo and would like to get a ball park for fuel pressure cause im having a problem keeping the car running at 35 psi
Old Jun 29, 2005 | 02:50 PM
dustin's Avatar
Default Re: fuel pressure suggestions (elusive123)
well, then it's probably not the fuel pressure causing the problem.
what are you doing for injectors/ems?
Old Jun 29, 2005 | 03:43 PM
elusive123's Avatar
Default Re: fuel pressure suggestions (dustin)
i have rc 500
it's gotta be fuel cause if i crank the engine over with no spark then hook spark up it will start fine and run till the mixture and or turbo starts to spool which causes a lean mix ,
i broke the motor in with thecharge pipe disconnected and had bout 25 psi and the car ran fine
BoostinTEG
Sep 5, 2011 10:20 AM
ken2830
Jul 5, 2011 07:33 AM
ken2830
Nov 3, 2009 09:28 AM
red91hatch
May 18, 2008 02:27 PM
