i'm horny for nitrous
well, i have a 2000 accord 4 cyl, auto blah blah blah.
have about 1500 to blow , and always had a hardon for N2O, here is my question:
i've been doing some research for the past couple of years on different nitrous set ups, and decided for me its best to go with direct port or wet kit, because engine life is my no 1 concern...it is my second engine, so i think i realized the limits of my stock ringlands(****). I really like the venom 2000 kit set up with linear pattern, that would spray according to the position of the tps sensor and spray smaller % of nitrous initially and go up to full shot as rpms climb, but realised that the venom kit that i was looking for, hooks up in your intake, making it a dry kit, when i was looking for wet or direct port. Does venom or any other manufacturers make a kit with similar progressive controller and wet or direct port as an option? thx
you might not blow your mtoor but you sure will **** up your tranny . have fun with that one. the linear nitrous shot is a definate plus. esp for automatic . the sudden shock of nitrous will mess up your tranny big time.
get a trannycooler for sure
NOS makes a progressive controller. however i dont think it works like that.
P.s. you might wanna see your doctor about that sexual problem you have for nitrous.
but seriously though there is no kits out there that would do wet/direct set up and progressive controller?!, cant you just custom wire it in after u tap the manifold for instance, or does the set up have to come as a "kit"
BTW already have tranny cooler...and reason getting progressive set up is mostly BECAUSE its an automatic, but thanks for heads up anyways+ not trying to spray over 60 hp at the most
so how simple would it be to have wet or direct port set up together with progressive controller, for instance if i was to go with NX botttle , jets, etc., could i use venom progressive controller, or does it have to be NX controller? (I believe they make one, just not sure if it has linear mode)
