fuel pump?
Old Jun 29, 2005 | 01:35 PM
Rubixcu7's Avatar
Default fuel pump?
about how long would i be able to run my stock fuel pump on a low boost setting before i lean out and blow?
Old Jun 29, 2005 | 01:40 PM
s2kdre's Avatar
Default Re: fuel pump? (Rubixcu7)
i wouldnt chance it because it cant pump enough fuel anyways.
Old Jun 29, 2005 | 01:44 PM
tgreaves's Avatar
That depends on what size injectors and what fuel management your using..
Old Jun 29, 2005 | 07:32 PM
NotUrAvgSi's Avatar
just get the walboro 255 cant go wrong
Old Jun 30, 2005 | 02:20 AM
Rubixcu7's Avatar
greddy kit on stock psi on stock injectors w/ a 12:1 FMU
Old Jun 30, 2005 | 05:38 AM
notoriousB's Avatar
Default Re: (Rubixcu7)
you can't. you'll blow your motor w/ that FMU + stock pump. Get an inline pump.
Old Jun 30, 2005 | 05:39 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rubixcu7 &raquo;</TD></TR><TR><TD CLASS="quote">w/ a 12:1 FMU</TD></TR></TABLE>
Get a walbro 255hp fuel pump.. I wouldnt even thing of boosting on a stock fuel pump with an fmu..
Old Jul 1, 2005 | 12:53 AM
Rubixcu7's Avatar
could i run w/out new pump and no FMU for a little bit or is that gong to run me too lean?
Old Jul 1, 2005 | 05:43 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rubixcu7 &raquo;</TD></TR><TR><TD CLASS="quote">could i run w/out new pump and no FMU for a little bit or is that gong to run me too lean?</TD></TR></TABLE>
Well you need some way for fuel to be added while in boost.. The stock ecu doesnt have provisions for adding fuel in boost so thats what your fmu does.. I would just leave everything the way it is and not boost on it until you get a fuel pump..
For as cheap as the pumps are its not worth blowing your motor over it..
KrispyKreme
Apr 20, 2005 03:52 PM
Unjockable
Dec 24, 2004 11:05 PM
civproject14
Dec 19, 2004 10:07 PM
B18badboy
Jan 12, 2004 10:57 AM
harryg
Sep 24, 2003 01:47 PM
