Compression test results...
Old Jun 27, 2005 | 12:56 PM
SOHC_MShue's Avatar
Default Compression test results...
d16y8 block with 100k miles on it(been boosted for 10k) with an almost brand new z6 head(under 10k original miles on it).
4 3 2 1 ( order)
180 175 175 190
how do these look?
Old Jun 27, 2005 | 01:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Compression test results... (SOHC_MShue)
those numbers are uniform, all within 10-15% if you are scared, do a cylinder leakage test. but those look good to me.
Old Jun 27, 2005 | 01:09 PM
SOHC_MShue's Avatar
Default Re: Compression test results... (boostedcivicsir)
well what worries me is that i lost about a quart of oil in 2 weeks time. I think it has something to do with my extremely leaky return line though and a possibly leaking crank seal. My friends say that my car never smokes like its burning oil when i get on it and there is no noticable blowby out of the valvecover breather.
Old Jun 27, 2005 | 01:53 PM
SOHC_MShue's Avatar
bump it up
Old Jun 27, 2005 | 02:00 PM
Mr. Badwrench
a cylinder leakage test will tell you if the rings are goin south.
Old Jun 27, 2005 | 02:06 PM
SOHC_MShue's Avatar
yea i suppose i should do that.
Old Jun 28, 2005 | 08:26 AM
SOHC_MShue's Avatar
Alright i'm getting inconsistent results here...
did another test today and got something like
170 170 165 170
then rechecked them again just to be sure and got
190 200 205 205
this compression tester is brand new
Old Jun 28, 2005 | 08:49 AM
Mr. Badwrench
was the engine up to opperating temp? if not get it there first.
Old Jun 28, 2005 | 11:09 AM
EJ1 wilcox's Avatar
- Was the engine all the way warmed up?
- Did you hold the throttle at WOT during the tests?
- How many times did you crank the engine during each test? Until the psi stopped increasing or a set number of times?
You shouldn't have that much of a difference between the two tests that you did. The compression numbers should be consistent. You must have done something different in the two tests that you did.
Old Jun 28, 2005 | 05:46 PM
SOHC_MShue's Avatar
Default Re: Compression test results... (EJ1 wilcox)
yes i did all of those things. Also i cranked it until the pressure stopped rising.
Old Jun 29, 2005 | 02:50 PM
BlackCRX's Avatar
bump for a fellow boosted D
Old Jun 29, 2005 | 03:12 PM
SOHC_MShue's Avatar
Default Re: (BlackCRX)
Old Jun 29, 2005 | 05:43 PM
waveoff's Avatar
Default Re: (SOHC_MShue)
After 70,000 boosted miles on my D16Y8 my compression numbers in 1-2-3-4 were 185-185-188-187. I still had the same numbers even with a blown headgasket.
Old Jun 29, 2005 | 05:58 PM
SOHC_MShue's Avatar
Default Re: (waveoff)
yea i don't think blown headgaksets ever show up often in compression tests unless they are really bad.
Old Jun 29, 2005 | 06:04 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">well what worries me is that i lost about a quart of oil in 2 weeks time. I think it has something to do with my extremely leaky return line though and a possibly leaking crank seal. My friends say that my car never smokes like its burning oil when i get on it and there is no noticable blowby out of the valvecover breather. </TD></TR></TABLE>
well i burn oil when i get on it...and in normal driving...but no smoke in normal driving, and the oil still disappears! but when i get on it(with a car behind me with its lights on) you can see smoke....yet my compression is PERFECT 240 all the way accross. so i guess the compression test doesn't say **** (cept my ringlands aren't cracked )
Old Jun 29, 2005 | 06:05 PM
SOHC_MShue's Avatar
Default Re: Compression test results... (m R g S r)
how much oil do you lose? Anywhere near as much as mine?
Uncle Ben's
Dec 8, 2007 12:21 PM
John.
Jun 12, 2006 08:45 AM
jeison
May 13, 2006 05:00 PM
Azcheron
Jun 23, 2005 09:34 PM
mafay2
Nov 11, 2004 07:34 PM
