problem with new turbo
Old Jun 27, 2005 | 10:29 AM
redlseg's Avatar
Default problem with new turbo
i just moved the housings on the turbo to the position i needed to install the exhaust mani and intercooler piping and know the turbo has alittle shaft play. is that normal or did i just **** up my turbo . also can the oil seals be messed up know?
Old Jun 27, 2005 | 10:37 AM
-Trinitron-'s Avatar
Is your turbo new or has it been installed before? If it is not new, there may be some crud in there preventing the housings from closing back together properly. Take it back apart and make sure the inside channel is clean before reassembling.
Old Jun 27, 2005 | 10:58 AM
redlseg's Avatar
Default Re: (-TRINiTRON-)
the turbo is brand new and never been installed just got it from precision a week ago
Old Jun 27, 2005 | 12:02 PM
redlseg's Avatar
Default Re: (h-tman)
???anyone have any idea why it has alittle shaft play???
Old Jun 27, 2005 | 12:04 PM
EGP's Avatar
EGP
Default Re: problem with new turbo (h-tman)
It's fine to have a small bit of shaft play side to side, as long as the blades do not touch the walls of the turbo, it should be fine.
Old Jun 27, 2005 | 12:11 PM
s2kdre's Avatar
Default Re: problem with new turbo (EGP)
when you loosen up the clocking bolts thats when you can feel a little shaft play.
ninjaturtleEG
Aug 5, 2012 01:27 PM
hondaaccord94
Feb 13, 2006 03:10 PM
POWERINTEGRA
Nov 28, 2004 07:25 PM
da_konig
Apr 24, 2004 06:12 AM
B16CRXT
Apr 2, 2004 04:49 PM
