Blox turbo manifold clearance issues?
Im thinking about getting the blox b-series turbo manifold for an LS. The LS will be going into a Del Sol. It looks like there is a clearance issue between the placement of the wastegate and the hood. Does anybody know if this setup will work? Also, what is the quality of the blox manifolds, are they are reputable brand?
Last question...it says the manifold has a t3 flange. Does that mean i cant use a t3/t4 turbo setup? Im a noob. Thanks for the help.
Re: Blox turbo manifold clearance issues? (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">del sols come with a b16 and the blox mani fits on those. why wouldnt it fit on a ls? same ****.</TD></TR></TABLE>
No, it isn't. The base of the VTEC head is a bit wider, which can actually cause some clearance issues with the wastegate. The LS block is .200" taller than the B16 block, which if the wastegate is close on a B16 that .2" could push it right into the hood.
Re: Blox turbo manifold clearance issues? (b16sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan »</TD></TR><TR><TD CLASS="quote">
No, it isn't. The base of the VTEC head is a bit wider, which can actually cause some clearance issues with the wastegate. The LS block is .200" taller than the B16 block, which if the wastegate is close on a B16 that .2" could push it right into the hood.</TD></TR></TABLE>
Dude, same ****. 2 tenths of an inch isnt gonna matter. And I know for a fact that it will fit.
Re: Blox turbo manifold clearance issues? (NuclearB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuclearB18B »</TD></TR><TR><TD CLASS="quote">use a turbosmart wg instead of tial</TD></TR></TABLE>
Exactly, what I was going to say!
Re: Blox turbo manifold clearance issues? (11psiTurboSI)
hey my boy is running a blox manifold on his ls turbo in a 92-5 civic coupe and the wastegate won't clear the hood so just watch out
turbo*s2k
Northern California (Sales)
01-29-2006 04:08 PM
