Overheating while under boost..help please
Old Jun 29, 2005 | 04:01 PM
droc327's Avatar
Default Overheating while under boost..help please
hey everyone...my car started to over heat today when i was under full boost in fourth gear. i just changed my thermostat and it still does it. but as soon as i let off the gas the temp slow drops back to normal...could someone tell me what they think this could be? oh ya my coolant overflow tank is almost like its draining but there is no leakage anywheres that i can see...not even on the ground.
Old Jun 29, 2005 | 05:41 PM
waveoff's Avatar
Default Re: Overheating while under boost..help please (droc327)
Just for the heck of it, go to a radiator shop and have them do a "sniffer" test on your coolant to make sure you haven't blown your headgasket. Many radiator shops will do this for free. If it's negative then you can at least rule the headgasket out and look for other problems. I was in denial for a long time about my overheating under boost but it turned out to be the headgasket.
Old Jun 29, 2005 | 06:42 PM
droc327's Avatar
thanks...bump
Old Jun 29, 2005 | 09:06 PM
droc327's Avatar
anyone else
Old Jun 30, 2005 | 08:59 AM
FAUCON's Avatar
Headgasket....
Old Jun 30, 2005 | 10:31 AM
CRX T-Si's Avatar
Default Re: Overheating while under boost..help please (FAUCON)
Sounds to me like your running lean...is the motor tuned?
What EMS are you running for the turbo?
Old Jun 30, 2005 | 10:33 AM
EJ1 wilcox's Avatar
Default Re: Overheating while under boost..help please (CRX T-Si)
Sounds like a head gasket to me too...
Old Jun 30, 2005 | 10:36 AM
Erik B's Avatar
check your fuse under the hood make sure your fan is coming off....I was having that problem and it tunrs out someone (some shop) pulled my freaking fan fuse!!! *******...hahahaha
Good luck. O also you running a after market radiator cap?
Old Jun 30, 2005 | 10:51 AM
BlackCRX's Avatar
dont think its the fan switch cuz when you are doing a 4th gear pull theres so much air hitting the rad that the fan would almost be usless
my bet is headgasket as well
check your overflow bottle and see if its topped off, if it is, your headgasket is shot
Old Jun 30, 2005 | 11:56 AM
PhantomSTi's Avatar
Default Re: (BlackCRX)
Even if you don't have the signs of a head gasket and the tests come out to be fine. You could have a cracked/fractured head gasket which will act like a blown head gasket temp wise, but show no signs of one (White smoke, chocolate milk under the valve cover).
Old Jun 30, 2005 | 12:56 PM
waveoff's Avatar
Default Re: (90integra05)
What he said... When my headgasket went the only idications I had were overheating after boosting, full overflow tank, bubbling coolant in the overflow tank/radiator. If I shut off my car it would be fine...no bubbling coolant or overheating. But as soon as I boosted, it'd start overheating again. You have to have a MAJOR breach in the headgasket to get some smoke or chocolate milkshake.
1SlowSi
Dec 17, 2008 09:03 AM
boostmee
Jul 9, 2007 05:04 AM
giantdny
Nov 6, 2006 07:13 AM
14bcoupe
May 15, 2005 06:30 PM
eg2turbo
Dec 21, 2002 05:58 PM
