Crower 404s on turbo LS
Old Jun 30, 2005 | 09:42 PM
19sec beast's Avatar
Default Crower 404s on turbo LS
Are these cams mainly for all-motor applications on the B18b?
I'm about to buy some, but still undecided on which route to go.
Any suggestions also greatly appreciated.
Old Jun 30, 2005 | 09:49 PM
b16sedan's Avatar
Default Re: Crower 404s on turbo LS (19sec beast)
They're on par with some of the stock B-series VTEC cams. Try em, I think you'll see some big top end gains over 402T's.
Old Jun 30, 2005 | 09:56 PM
Default Re: Crower 404s on turbo LS (b16sedan)
I didn't really want to be a guinea pig, but oh well...
I guess I'll throw 'em in and hope for the best. I'll post dyno results after I get them tuned, etc.
I'm hoping for a strong flat torque line all the way to 8,000-8,500.
Old Jun 30, 2005 | 09:58 PM
b16sedan's Avatar
Even on 402T cars torque is dropping long before 8500. I think the 404's are your only shot. Think about how famous you'll be if you run these and they make filthy power and people are all like woo woo.
Old Jun 30, 2005 | 10:01 PM
The very thought of people chanting "woo woo" is motivation enough.
Old Jul 1, 2005 | 01:08 PM
Old Jul 1, 2005 | 01:44 PM
Sprayteg's Avatar
I would try it for sure, I run Crane 20 cams(bigger than the 404) and it work really well.
402T cams are great for less than 350hp. What your setup?
Old Jul 1, 2005 | 02:23 PM
DragSource's Avatar
I have heard good things of the Crower 403's. . . I'm sure the 404's will be good too.
I have heard that both are far superior to the 402t, as mentioned above.
I'd rock em'. . . I'll be sporting 403's, trying to make power to 8.5-9k on the ls is fun
I've seen plenty of dyno charts with LS's making power up to 8.5k and beyond though so I'm sure it is being done.
What kind of headwork do you have?
Old Jul 1, 2005 | 02:31 PM
Default Re: (DragSource)
I'm getting a P&P'd LS head w/ complete Crower valvetrain, new seals, Crower 404 cams, Skunk2 adj cam gears.
I've got a fully built bottom end without sleeves. I'm about to turn up the boost (it's at 4psi right now).
In my living room I've got a TurboXS MBC, TurboSmart 35mm wastegate, RC550cc injectors, GM 3 bar map sensor, and getting the head hopefully within the next 2 weeks.
Going to turn up the boost on my Garrett t3/to4e (63/60) to about 18psi and see what she can do.
I want 400whp and at least 370wtq with a strong and steady torque line to 8,000-8,500.
Old Jul 1, 2005 | 02:35 PM
DragSource's Avatar
Damn bro, we're going to be running a very similar setup.
JG Pro Ported Head
Crower 403's /springs/ret
Skunk2 Cam Gears
HX35 w/ 14cm^2 hot side
If yours is running before mine you'll have to keep me posted on how you like the 404's.
Old Jul 1, 2005 | 02:42 PM
I hear they have a nasty idle, but who knows.
I guess I'll find out the old fashioned way... through trial and error.
Old Jul 1, 2005 | 04:52 PM
DRAGLS's Avatar
Default Re: (19sec beast)
I am currently running the 404's on my LS all I can say is insane topend for an LS
Old Jul 1, 2005 | 05:58 PM
s2kdre's Avatar
Default Re: (DRAGLS)
what do the 404's make power up to?
Old Jul 1, 2005 | 09:53 PM
qksl2's Avatar
Default Re: (jdmhonda)
Anyone have specs on the 404's?
Ian
Old Jul 2, 2005 | 04:30 AM
DRAGLS's Avatar
Default Re: (qksl2)
This is what my cam spec sheet says
308*in/305*ex duration .445in/.434ex lift advertised specs
at .50" 226*in/224*ex duration .254in/.248ex lift
Crower says power from 1100rpm to 8200+rpm.
Old Jul 2, 2005 | 05:34 AM
DragSource's Avatar
On a ported head, will the same set of cams make power higer than on an unported head?
Old Jul 2, 2005 | 06:26 AM
qksl2's Avatar
Do you know the rocker ratio or lift/duration at the valve? Or is it direct acting?
Thanks!
Ian
Old Jul 2, 2005 | 05:17 PM
DRAGLS's Avatar
Default Re: (qksl2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">On a ported head, will the same set of cams make power higer than on an unported head?</TD></TR></TABLE>
Yes it will, the head I am using is pnp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qksl2 &raquo;</TD></TR><TR><TD CLASS="quote">Do you know the rocker ratio or lift/duration at the valve? Or is it direct acting?</TD></TR></TABLE>
The LS has an 1.75 rocker ratio.
97turboteg
Dec 16, 2005 03:12 PM
DragSource
Oct 19, 2004 11:44 AM
Teg4e
Jul 16, 2003 12:46 PM
LS_racer
Mar 11, 2002 03:12 PM
DRAGLS
Nov 24, 2001 06:35 PM
