cannot feel vtec
Old Jun 28, 2005 | 10:11 PM
teamitr's Avatar
Default cannot feel vtec
I have a vafc on my lude but lately I don't think my vtec have been turning on, its kind of hard to tell becuase i'm boosting but how could I check if its working, bk i think that maybe the vafc is not working since i bougth it used of a guys that lately has been doing some shady stuff in his shop. but how could i test it?
Old Jun 28, 2005 | 10:39 PM
Rod.'s Avatar
Default Re: cannot feel vtec (teamitr)
check your vtec solenoid. Could be clogged...start there
Old Jun 28, 2005 | 10:44 PM
BlueShadow's Avatar
Default Re: cannot feel vtec (redturbocivic)
I've been thinking about this too cause now my turbo GSR's crossover is too smooth. Plus I wanna test out and make sure that x-over is being set at the correct RPM point. I was thinking about hooking up a test light to see when my VTEC comes on.
Would a small lightbulb with one wire going to the VTEC wire and the other wire going to a ground work for a test light?
Old Jun 29, 2005 | 03:53 AM
dornon13's Avatar
Default Re: cannot feel vtec (BlueShadow)
yes that will work i plan on doing the same cuz im having the same worrys except mine is a SOHC so you cant feel it anyways but now with the open wastegate i cant hear it either
Old Jun 29, 2005 | 07:37 AM
teamitr's Avatar
Default Re: cannot feel vtec (dornon13)
As far as the cable what is the color that I could put a test ligth to? And how do you clean the vtec solenoid do i just loook inside of it and use degreaser or what?
Old Jun 29, 2005 | 01:51 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamitr &raquo;</TD></TR><TR><TD CLASS="quote">As far as the cable what is the color that I could put a test ligth to? And how do you clean the vtec solenoid do i just loook inside of it and use degreaser or what?</TD></TR></TABLE>
I dont rememeber the color of the wire, but there should only be the one wire that goes to your VTEC solenoid. AFAIK during VTEC x-over this wire gets a 12V signal from the ECU when the right conditions are met.
Old Jul 4, 2005 | 08:27 AM
teamitr's Avatar
ok I cheked the cable and i am getting a 12v signal and I gave a 12v signal to the solenoid and it did click but still cannot feel the vtec or hearing or notice any difference when i get to the rpm when its suppose to engage
blacktibby07
14
Feb 8, 2011 08:48 PM
Jimster480
17
Jul 27, 2010 12:39 PM
AnAccordIsForever
Jun 3, 2008 03:27 PM
the_rail
May 1, 2004 04:44 PM
H22AJSPEC
Sep 4, 2003 12:56 PM
