Blitz SBC ID boost controller over 25 psi!
Old Jun 28, 2005 | 12:45 PM
turbo*s2k's Avatar
Default Blitz SBC ID boost controller over 25 psi!
I know people are using the Blitz SBC ID boost controller , but I'm curious if any of you are running more the 25 psi on it.
I've always been able to get about 24 psi out of, but anything over that just doesn't work. I've adjusted the gain every which way, and nothing...
Old Jun 28, 2005 | 12:51 PM
g2turbo's Avatar
Default Re: Blitz SBC ID boost controller over 25 psi! (TurboChrgd_Civic)
Im sure you have thought of this already but what wastegate spring are you running. I know of a local guy in Cincinnati that has taken the controller to around 30 lbs.
Old Jun 28, 2005 | 01:05 PM
turbo*s2k's Avatar
Default Re: Blitz SBC ID boost controller over 25 psi! (g2turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">Im sure you have thought of this already but what wastegate spring are you running. I know of a local guy in Cincinnati that has taken the controller to around 30 lbs.</TD></TR></TABLE>
yes, I've used mulitple spring combos. (Tial 44mm wastegate)
1. Big blue .9 bar (13.05psi)
2. Big blue .9 bar / small yellow .25 bar (16.68psi)
3. And recently Big Blue .9 / and small blue .5 bar (20.30)psi
Maybe I need try a softer spring combo like a big green / small red (comes out to about 15 psi I think...
Old Jun 28, 2005 | 02:38 PM
alpha's Avatar
That's weird. We have took the Blitz SBC i-D to 34lbs.
Old Jun 28, 2005 | 03:09 PM
turbo*s2k's Avatar
Default Re: Blitz SBC ID boost controller over 25 psi! (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">That's weird. We have took the Blitz SBC i-D to 34lbs.</TD></TR></TABLE>
What was your gain setting set at?
Old Jun 28, 2005 | 03:13 PM
alpha's Avatar
I think at the time it was at 38 or 42.
Old Jun 28, 2005 | 03:47 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">I think at the time it was at 38 or 42.</TD></TR></TABLE>
okay, thanks!
Old Jun 28, 2005 | 04:16 PM
TheShodan's Avatar
Moderator
Remember. The SBC-ID boost controller came in the SPEC S ( good to 1.5bar solenoid) and the SPEC R Dual solenoid (Good to over 2.5bar). Depending upon the spring used, you may have to get another controller entirely. The solenoids do not interchange with the electronic devices.
Old Jun 28, 2005 | 04:21 PM
turbo*s2k's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Remember. The SBC-ID boost controller came in the SPEC S ( good to 1.5bar solenoid) and the SPEC R Dual solenoid (Good to over 2.5bar). Depending upon the spring used, you may have to get another controller entirely. The solenoids do not interchange with the electronic devices.</TD></TR></TABLE>
I'm not sure what your saying exactly, but The SBC i-D features the same dual solenoid design as the DSBC for maximum boost response and the capability to hold up to 36.75psi (2.5 bar).
Old Jun 28, 2005 | 04:22 PM
alpha's Avatar
Very good point. I forgot they had single and dual solenoids.
Old Jun 28, 2005 | 04:25 PM
alpha's Avatar
Default Re: (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not sure what your saying exactly, but The SBC i-D features the same dual solenoid design as the DSBC for maximum boost response and the capability to hold up to 36.75psi (2.5 bar). </TD></TR></TABLE>
There is actually two different SBC i-D boost controllers. One uses a single solenoid while the other uses a dual solenoid.
Old Jun 28, 2005 | 05:58 PM
PrettyLude's Avatar
can we get a picture of the single and double solenoids? im pretty sure i have the dual solenoid design, **** cost me 500 bones
Old Jun 28, 2005 | 07:41 PM
alpha's Avatar
Default Re: (PrettyLude)
Old Jun 28, 2005 | 07:44 PM
alpha's Avatar
Default Re: (0x64)
Old Jun 28, 2005 | 07:49 PM
PrettyLude's Avatar
that's how mines look
Old Jun 28, 2005 | 09:05 PM
turbo*s2k's Avatar
Default Re: (0x64)
There is actually two different SBC i-D boost controllers. One uses a single solenoid while the other uses a dual solenoid.</TD></TR></TABLE>
I don't think so. The Dual SBC Spec R is dual solenoid, and the Dual SBC Spec S is single solenoid. The Blitz SBC ID is dual solenoid. I don't see a single solenoid SBC ID on there Blitz website.
But regardless, Mine is dual solenoid.
Sketch_hs
Aug 5, 2004 10:10 PM
jure
May 6, 2004 02:32 PM
G U E C O
Dec 9, 2003 02:43 PM
yusoslo
Jul 12, 2003 08:01 PM
BoostedSi
Feb 11, 2003 10:08 AM
