manifold gasket?
Old Jun 28, 2005 | 09:13 PM
the.hamburglar's Avatar
Default manifold gasket?
what gasket should i use between the manifold and cylinder head? also should i just reuse the stock nuts to put the manifold back on with?
Old Jun 28, 2005 | 09:41 PM
lodo1's Avatar
Default Re: manifold gasket? (hamburgler)
well, you would use the stock gasket for which ever engine your using. as for the exhaust nuts, you should replace them
Old Jun 29, 2005 | 11:05 PM
Default Re: manifold gasket? (tdocrx)
is there a special kind of nut or just go to honda and pick some up? i have the manifold but no gasket. should i just run the stock gasket that was on there before?
Old Jun 29, 2005 | 11:25 PM
SiKid86's Avatar
wow
Old Jun 29, 2005 | 11:50 PM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote">is there a special kind of nut or just go to honda and pick some up? i have the manifold but no gasket. should i just run the stock gasket that was on there before?</TD></TR></TABLE>
use your stock gasket and go to honda for the nuts
Rick1t
Feb 9, 2015 05:44 PM
didyouhearthat
Nov 10, 2013 08:11 PM
CaliforniaDad
Aug 9, 2011 09:02 AM
Wazup
Sep 10, 2005 05:24 PM
Paluce
May 26, 2005 09:58 AM
