how are my plugs???
Old Jun 29, 2005 | 03:29 PM
boostedeghatch's Avatar
Default how are my plugs???
http://www.we-todd-did-racing....D.jpg
running a gsr with JRSC, 6psi, fuel pressure at idle is at 45-47psi.
on the way home, i did a WOT pull, pulled into the driveway, turned the car off, pulled the plugs out.
Old Jun 29, 2005 | 05:13 PM
adseguy's Avatar
Default Re: how are my plugs??? (boostedeghatch)
running a tad rich, nothing bad though and the ground strap also tells me you are running a little too hot. What heat range are those plugs and what's your timing at? Overall they look OK though
Old Jun 29, 2005 | 05:41 PM
dc2legend's Avatar
Default Re: how are my plugs??? (adseguy)
They look like 7's
Old Jun 29, 2005 | 05:50 PM
non-VTEC's Avatar
they look fine for a boosted car.........plus they look fairly new so give the ground strap some more time to change colour.....
Old Jun 29, 2005 | 06:31 PM
NGK's 7 heat range
not sure on what the timing is set at. i think it might be at 12 - 14 BTC. i am using the jackson racing Map controller as i just got the kit and installed it as is.
i turned the fuel pressure down to 42psi at idle with the hose on. taking the hose off, it goes up to about 50 or 52psi, don't remember.
Old Jul 26, 2005 | 07:06 AM
vipps's Avatar
up
Old Jul 26, 2005 | 08:32 PM
oscarmayer's Avatar
you are supposed to set pressure always witht he hose off not on... could be why your rich.
i also detect a slight big of learnign at the top enmd becaue the tip of the plug (metal that sparks and you adjsut yes i forgot the exact name) looks a bit scortched and pitted signs of upper end leaning. I think that map may be wrong for you.
but this is my opinion. I'm not a big tuner guy.
Old Jul 26, 2005 | 08:49 PM
yeah.. those plugs were fairly new when i took those pics.
the tips don't look like that anymore. they are a little blackish/brownish now.
stockb18c
Jun 4, 2009 09:08 PM
ironcheftony
Jun 11, 2007 08:55 AM
yz125rider21
Jan 17, 2006 03:54 PM
Infinite Auto
Nov 6, 2005 02:04 PM
Boost Addict
May 19, 2004 08:04 PM
