stock ls/vtec turbo
Old Jun 29, 2005 | 06:24 PM
hondaluva's Avatar
Default stock ls/vtec turbo
Can i run a stock ls/vtec turbo with arp rod bolts and and rev to 8k? I only plan to run 6 psi until i build a ls block but until then this was my plan. I have heard of people running stock ls and gsr blocks on low boost and making mid 200 hp so i was wonder if this can work for me with the above stated and maybe a cometic head gasket. Thanx for the help I'm trying to have this thing together by the end of the summer i got everything to go ls/vtec except the vtec kit. So i was gonna put the head on my stock block and then bolt on the turbo by the end of the summer.
Old Jun 29, 2005 | 06:36 PM
11SEC CIV's Avatar
Default Re: stock ls/vtec turbo (hondaluva)
Im pretty much in the same boat as you--I blew my gsr block at the end of last year---threw together a ls/vtec until the gsr block is built--
golden eagle conversion kit
golden eagle block guard
arp headstuds
no dyno #'s and its not tuned--went 13.30 @105 5-6psi
Old Jun 29, 2005 | 06:40 PM
hondaluva's Avatar
Default Re: stock ls/vtec turbo (12SEC CIV)
what ecu are you running????
Old Jun 29, 2005 | 06:41 PM
11SEC CIV's Avatar
p72
Old Jun 29, 2005 | 07:05 PM
hondaluva's Avatar
obd1 or 2
Old Jun 29, 2005 | 07:10 PM
11SEC CIV's Avatar
OBD-2
oh-btw--I rev to 8100 all the time at the track
(dont really drive car hard on street)
7k+ miles
Old Jun 29, 2005 | 07:12 PM
lsvtecracer's Avatar
Well, i'm running a stock ls/vtec turbo setup and rev to 8k rpm all day long. The block is completely stock at 12 lbs of boost. I dyno at 261whp and 212 lbs of torque. A good tune will do wonder for you. I do have arp head stud though. You should be okay to 8k on stock rod bolts if you have a good tune.
hondaluva's Avatar
thank for the help man.... anybody else???? oh yeah 12SEC CIV how do you plan to tune your car
Old Jun 29, 2005 | 07:14 PM
Rod.'s Avatar
my friend runs to 8k everytime on his stock ls/vtec...soon to be turbo whenever he puts it on
Old Jun 29, 2005 | 07:16 PM
Default Re: stock ls/vtec turbo (redturbocivic)
Hey redturbocivic. What's your setup?? Tony tune my car on neptune, but my stock greddy dp and 2.5" catback was holding me back. I'm probably going to bring the car back to dallas after I get the 3" dp and catback.
Old Jun 29, 2005 | 07:18 PM
hondaluva's Avatar
i was just making sure. i have arp head studs and rod bolts just wonder if the was anything else i need in anticipation of boost. Like a metal haedgasket like a cometic or for all you mid atlantic people a inline pro gasket.
Old Jun 29, 2005 | 07:20 PM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaluva &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah 12SEC CIV how do you plan to tune your car</TD></TR></TABLE>
honestly, im not going to tune it! my gsr build is complete and awaiting to be dropped in---currently running 440's and vafc hack
when i have it 10 psi w/ 110 oct...feels much faster then gsr did
(if i was to guess, 325ish)
dont be scared to rev it
Old Jun 29, 2005 | 07:23 PM
Rod.'s Avatar
pm'd you lsvtecracer on setup
Old Jun 29, 2005 | 07:25 PM
hondaluva's Avatar
thanks for all the help peeps the head should be on in a month. Just need to know about the thicker headgasket.
Old Jun 29, 2005 | 07:29 PM
11SEC CIV's Avatar
if i could've did the build a little diff--i woulda used a inline pro 2mm headgasket
Old Jun 29, 2005 | 07:37 PM
hondaluva's Avatar
12SEC CIV are you running a knock sensor???
Old Jun 29, 2005 | 09:27 PM
agrn93ls's Avatar
i think this motor will take alot more abuse than you think it will. i have a stock LS/vtec and will be turbo in a couple of weeks. i will try to get about 250-300 hp out of it and i have a stock headgasket and all. and you could rev to 8k all the time. i actually was eerie of the same thing you are called Tony and asked him what he thought and he confidently said to rev to 8k n/a or boost.
Old Jul 1, 2005 | 09:45 PM
hondaluva's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaluva &raquo;</TD></TR><TR><TD CLASS="quote">12SEC CIV are you running a knock sensor???</TD></TR></TABLE>
for that mater does anybody know if i have to run a knock sensor:
96 Integra RS
stock b18b block
stock '00 Si b16 head
obd2a p72 gsr ecu
vafc
oh and can i use the Si distributor with a odb2a ecu even though it's of an obd2b car
Old Jul 5, 2005 | 07:34 PM
hondaluva's Avatar
bump for answer to the above
Old Jul 5, 2005 | 08:21 PM
agrn93ls's Avatar
uhh correct me if im wrong but you mentioned 3 OBD2 parts and asked if you could use them together, right? or did you mean one of those things actually isnt?
all OBD parts would be best, they all work together and plug in together. i use a knock sensor.
Old Jul 5, 2005 | 09:50 PM
Cimburke23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaluva &raquo;</TD></TR><TR><TD CLASS="quote">for that mater does anybody know if i have to run a knock sensor:
96 Integra RS
stock b18b block
obd2a p72 gsr ecu
vafc
oh and can i use the Si distributor with a odb2a ecu even though it's of an obd2b car</TD></TR></TABLE> yes, the Si dizzy should plug in, if you have the right plug on the harness
Old Jul 5, 2005 | 09:51 PM
Cimburke23's Avatar
Default Re: stock ls/vtec turbo (Cimburke23)
oh, and i have a stock LS/vtec setup, gsr head w/ skunk2 manifold, inline pro t3 manifold, t3/to4e turbo, plan on trying to make 300+whp w/ it tuned w/ hondata ill let u kno when its complete
Old Jul 7, 2005 | 09:49 AM
hondaluva's Avatar
ok so any pics of where you put your knock sensors.
silverdc2integra
Sep 28, 2009 11:17 AM
98GSR-Turbo
Nov 16, 2008 06:57 PM
2 point 0
Apr 22, 2004 03:11 PM
Homer_Simpson
Sep 5, 2001 05:16 PM
