Oil sandwich plate question
Hey guys, i know.. i searched and this topic has popped up a million times, but i can't really find my answer.
For one, does the Greddy plate work w/ the stock oil cooler on the GSR?
And secondly. I can't really figure out how the hell it goes on. Theres 2 Fittings that came with the plate. Are one of these supposed to fit in the block? Cus they don't.
For such a simple piece im confused.. I guess im retarded.
what do u mean is a fitting supposed to gointo the block? a fitting should go into the turbo if anything. a sandwich plate elimates gaving to screw into the block
Re: Oil sandwich plate question (kuja)
kuja, are you taking about the two large fittings that were screwed together when you first bought it?
One of those is supposed to go through the oil filter sandwich adapter and screw onto where the stock oil filter goes. Your oil filter then screws onto the new Greddy adapter.
Re: Oil sandwich plate question (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">kuja, are you taking about the two large fittings that were screwed together when you first bought it?
One of those is supposed to go through the oil filter sandwich adapter and screw onto where the stock oil filter goes. Your oil filter then screws onto the new Greddy adapter.</TD></TR></TABLE>
yup, that's how it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">One of those is supposed to go through the oil filter sandwich plate and <u>screw onto where the stock oil filter goes</u>. Your oil filter then screws onto the new Greddy adapter.</TD></TR></TABLE>
The greddy adapter will keep the Greddy plate in place. That's all there is to the install, all you do is make sure the Greddy plates O rings are facing the block.
Pompiuses
09-03-2010 09:29 AM
hondalovinEK9
08-24-2007 06:00 AM
