Pressure in the head!?!?!?
Old Jun 28, 2005 | 05:36 AM
carlip's Avatar
Default Pressure in the head!?!?!?
Recently boosted my civic, cutting a long story short, my camshaft seal (cam gear side) popped out and oil leaked out. The camshaft seal was fine.
After unplugging the breather on the rocker cover, i noticed a lot of pressure in the head.
Car "seems" to run ok.
First thoughts are piston ring is worn or perished.
Could anyone shed any light...?
Thanks and regards,
Carlip.
Old Jun 28, 2005 | 05:50 AM
Dragline's Avatar
Default Re: Pressure in the head!?!?!? (carlip)
Is your pcv valve bad?
Old Jun 28, 2005 | 05:53 AM
mike1114's Avatar
Default Re: Pressure in the head!?!?!? (dragline)
inadequate crankcase ventilation
Search for thread created by dasher for more info on what to do.
You need more ventilation, endyn breather kit, ports welded onto valvecover.
READ DASHER's THREAD.
and for gods sake search, this topic has seriously been covered a billion times.
Search Results
Your search for crankcase ventilation returned 10 results.
this was just in recent topics.
Old Jun 28, 2005 | 06:27 AM
SOHC_MShue's Avatar
excessive blowby is usually caused by messed up rings or ringlands. That is probably your problem.
Old Jun 28, 2005 | 03:16 PM
carlip's Avatar
Default Re: Pressure in the head!?!?!? (mike1114)
Must apologise for not using the search, but i didn't know what to search for...!?
The links and info you provided helped me out though, thanks for that.
phoshyzzle
May 25, 2008 10:02 PM
juanchoenuncrx
Mar 8, 2008 10:33 AM
I3ackfire
13
May 11, 2004 08:45 PM
uneekcrx
Apr 1, 2002 08:27 PM
el_Presidente
Feb 19, 2002 01:08 PM
