will my b20 fail? please help!
Old Jun 30, 2005 | 09:30 AM
R6E6I6D's Avatar
Default will my b20 fail? please help!
i recently purchased all that is required for a turbo set up but will be running with the stock obdo integra ecu, I will be running a seto of 450cc dsm injecters, retard the ignition manually, 12:1 blox FMU, and a missing link MAP bypass valve, I will be running the static spring in my gate of 5.83 and will not be exceeding this untill my motor is built for more pressure... I have been told I should be just fine and it will run a little rich, and I have been told I will crack a sleeve within a week or so(which I dont beleive cause ive seen ppl running in upwards of ten psi on a stock b20 bottom end, not saying its good but 5.83 that aint ****)... well if you can help me please give me some insight
Old Jun 30, 2005 | 09:43 AM
SOHC_MShue's Avatar
Default Re: will my b20 fail? please help! (R6E6I6D)
Just ask yourself this question....why would you run an fmu and 450cc injectors with a stock ecu?
Old Jun 30, 2005 | 09:54 AM
b20turboic's Avatar
Default Re: will my b20 fail? please help! (SOHC_MShue)
id sell the fmu setup and get that ecu chipped for a few dollars and pocket the rest. Go download turbo edit its free to use then get it tuned. My stock B20 made 300 whp and 296 wtq through 2 1/4 exhaust. Motors hold up if tuned mine lasted 2 years at that power level till i built a motor and pulled the running b20 out. TUNE TUNE TUNE ..
Old Jun 30, 2005 | 10:01 AM
pimpintyperintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Just ask yourself this question....why would you run an fmu and 450cc injectors with a stock ecu? </TD></TR></TABLE>
yes, very true...get rid of the fmu and get a decent system to tune your car and you should be fine
it really is all about tuning, so get someone that knows what they are doing
Old Jun 30, 2005 | 10:51 PM
R6E6I6D's Avatar
Default Re: will my b20 fail? please help! (pimpintyperintegra)
you dont think its worth it to just run the car with the fmu and make some more cash b4 i get hondata, cause i got a obd0 and i need a socketed obd1 to run hondata... and that just costs a **** load of cash which idont have yet and wont for a while of saving
Old Jun 30, 2005 | 11:48 PM
NumberB's Avatar
if you care about your car screw the fmu and get it tuned.
Old Jul 1, 2005 | 06:10 AM
R6E6I6D's Avatar
Default Re: will my b20 fail? please help! (milb16a)
i could take it out to plainfield IL to whipp factory, they are just about the best tuners in the midwest... and I just want to know what Id have to do in order to get the obd1 ecu working with my set up which is obd0
Old Jul 1, 2005 | 06:25 AM
deftones0817's Avatar
uberdata or crome do a search....your free ems with a chipped ecu is only around 30-50 bucks. Then burrow someones wideband and go to down or have someone else do it.
CRX 2.0V-T
Nov 12, 2005 11:04 AM
Tacoma Luda
Jul 25, 2005 09:47 AM
Turboredteg
Jan 28, 2005 06:38 AM
cliff666
Jun 29, 2004 06:34 AM
arsenaldragster
May 27, 2003 07:59 PM
