Newbie turbo program question
Old Apr 1, 2007 | 04:49 PM
SinisterSentra91's Avatar
Default Newbie turbo program question
I have searched and found nothing but maybe Honda lingo is different from the Nissan lingo im use to. Anyway a buddy of mine has a CRX, we are doing a B18A1 swap into it. I understand everything on doing the swap. We want to throw a turbo setup on it while the engine is out of the car. We are using a small DSM turbo, I believe its a T25 not sure. My question is will the B18A ECU be able to handle the turbo or does it have to be upgraded? I am asuming it has to be upgraded. Where can I get an upgraded ecu and which injectors do I use? Im trying to make this pretty much plug and play as my friend is pretty mechanical illiterate and I dont have the time to teach him lol. Thanks alot.
Old Apr 1, 2007 | 04:56 PM
teddy_dc2's Avatar
yes ecu will need to be upgraded to run properly, if you want just a basic boost injector, i'd go with dsm 450cc's. more info go to homemadeturbo.com or search around here to see what people run.
Old Apr 1, 2007 | 05:05 PM
Bseriescivic5's Avatar
you will need some kind of socketted ECU, a P06 i believe since that car is obd-0, can use turboedit to tune it slap a base map in for the 450cc injectors, or you could run a FMU but id suggest not. Might also want to upgrade the fuel pump as well.
Old Apr 1, 2007 | 06:30 PM
Default Re: (Bseriescivic5)
How do I use the turbo edit, is there a tutorial? Im not trying to get real deep into this swap as I have my own project car to tend to. Im just looking for something cheap and easy that I can plug in and go.
Old Apr 1, 2007 | 06:50 PM
teddy_dc2's Avatar
pgmfi.org
Mitch965
Jun 16, 2012 11:33 AM
hastingsr
Apr 16, 2009 12:49 PM
sLyBlAzNbBoI
Engine Management and Tuning
Jan 10, 2009 05:57 AM
sccivic
Aug 31, 2007 07:40 PM
It's*BOLO!!
Feb 6, 2003 10:00 AM
