Heat wrap for downpipe?
Old Apr 6, 2007 | 10:52 AM
D15Bbigred's Avatar
Default Heat wrap for downpipe?
I am using a a spoolin downpipe in my setup. In the setup I'm still using a/c. Would it be wise to heat wrap my downpipe? or anything else. or just let it be the way it is? Thnx for any help.
Old Apr 6, 2007 | 09:56 PM
D15Bbigred's Avatar
up
Old Apr 6, 2007 | 10:06 PM
ProJectCvic's Avatar
Default Re: (D15Bbigred)
I would heat wrap the manifold before I heat wrap the down pipe.
Old Apr 6, 2007 | 10:09 PM
slowteg90's Avatar
Default Re: (ProJectCvic)
ive heard it was bad to heat wrap the mani and dp because the exhaust temps would be alot hotter? forgive me if im wrong, its 2:15am here....
Old Apr 6, 2007 | 10:17 PM
Default Re: (slowteg90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg90 &raquo;</TD></TR><TR><TD CLASS="quote">ive heard it was bad to heat wrap the mani and dp because the exhaust temps would be alot hotter? forgive me if im wrong, its 2:15am here.... </TD></TR></TABLE>
This is true if your manifold is shitty . You are right in thinking this though. However, a quality made manifold would take the heat cycle.
Old Apr 7, 2007 | 07:59 AM
D15Bbigred's Avatar
well its a spoolin mani, i guess i'll ask phil.
Old Apr 7, 2007 | 08:24 AM
adseguy's Avatar
Yeah they would stay hotter.....so what, this is post enigne which is why you take Exhaust Gas temps anyway.....for the engine itself.
Yeah go ahead and wrap them up. Under hood temps will drop, but the downside is that moisture gets stuck in the fibers and will corode your pipes a lot faster then normal.
Old Apr 7, 2007 | 08:40 AM
Default Re: (adseguy)
You can use high temp silicon spray to help with the corrosion. Higher exhaust temp=higher thermal energy....which is the actual purpose of the turbo!
Old Apr 7, 2007 | 08:44 AM
racin_jayson's Avatar
Heat wrapping my downpipe really helped keep my intercooler from getting heat-soaked, In stop & go traffic my intake temps are way down
Old Apr 7, 2007 | 09:42 AM
D15Bbigred's Avatar
wow thnx for the responses so far guys. Some good ideas. where can i get the high temp silicon spray? and DEI heat wrap is just as good as anything right?
boostedBLUfg2
Feb 17, 2011 06:12 PM
mrx
Feb 26, 2006 11:22 AM
mamaboy
Welding / Fabrication
11
Aug 4, 2005 09:19 AM
opto_isolator
Jul 31, 2004 10:14 PM
yellowbulbs
Jul 25, 2001 02:19 PM
