SPUN ROD BEARING???? What to hear for...
Old 04-01-2007, 12:03 PM
peakboosth22's Avatar
Default SPUN ROD BEARING???? What to hear for...
I think that there is something wrong with my motor. Ever since i busted my headgasket, which i replaced about two weeks ago, I keep hearing a constant ticking noise that goes away after 2500rpm. The ticking noise is at its highest right start up. All this noise started as soon as warped my headgasket.
FORGED honda H22 TURBO
!.) the motor idles fine
2.) IT still response well when at booost.
3.) oil dip stick shows no shiny metal bits
4.) COMPRESSION TEST was good
5.) Valves clearence was good
Modified by peakboosth22 at 1:22 PM 4/1/2007
Old 04-01-2007, 12:11 PM
HT White Ops
SD_Lurker's Avatar
Default Re: SPUN ROD BEARING???? What to hear for... (peakboosth22)
Do you need a vavle job buddy? Ticking usually occurs when vavles become loose. Knocking sounds would be that of a bearing.
Old 04-01-2007, 01:06 PM
Puscifer's Avatar
Default Re: SPUN ROD BEARING???? What to hear for... (SD_Lurker)
Yeah typically you KNOW when you spun a rod bearing.. I know when I spun two it sounded like someone beating on my engine block with a sledgehammer
Old 04-01-2007, 01:14 PM
Default Re: SPUN ROD BEARING???? What to hear for... (Puscifer)
It definatly does not sound like someones is on the inside of the motor with a sledgehammer.
Old 04-01-2007, 01:25 PM
HT White Ops
SD_Lurker's Avatar
I would advise you to get a vavle job and see if the problem persists!
Touge Tuning
07-04-2006 09:13 AM
shannon
12-21-2003 07:43 AM
ahunt01
06-21-2003 05:11 PM
Buzzbomb
16
01-08-2002 01:29 PM
Quick Reply: SPUN ROD BEARING???? What to hear for...
