GT35 Set up
wondering if anyone is running -10an lines and fittings with their GT35? if so where did you guys buy the -10an fitings to fit into the turbo or wat size are the water ports on the turbo. thanks
Are you talking about using -10an fittings for the water lines, because if so, myself and most other use -6an lines and I think that is more than enough, -10an would be huge for water lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast01se »</TD></TR><TR><TD CLASS="quote">would -4an water lines be to small?</TD></TR></TABLE>
_4an is fine -6 is just a little more flow. _10 is just rediculous and overkill. I recomend to anyone hooking up their coolant lines on their gt turbos to make sure where ever you put them is not leading directly toward a coolant temp sensor as it wil giv eyou false readings. Coolant coming out of the turbo is super hot
