To those with 3" DP, bolt question.
Old Apr 3, 2007 | 03:38 AM
BDogggUT34's Avatar
Default To those with 3" DP, bolt question.
What kind of bolts do you guys have in there to secure to the turbo housing? Are they just regular hex, studs w/ nuts, or bolts with the allen wrench hole? I'm currently test fitting my DP to the turbo and it has studs w/ nuts. I think it is on there tight but the nuts are starting to strip from hitting the DP while tightening. I'm afraid later on if i need to remove something, the nuts will be so stripped i wont be able to get them off. What do you guys think about the allen wrench bolts? They have a smaller head so i thought those would work perfect. If anyone has any pics of their 4-bolt turbo w/ 3"DP please post. Thanks
Old Apr 3, 2007 | 04:43 AM
Autoworks's Avatar
Default Re: To those with 3" DP, bolt question. (BDogggUT34)
Allen wrench bolts
(I actually use 2 allens ane 3 hex) Allens are a must when it's so close to the 3" DP on the flange
Old Apr 3, 2007 | 05:35 AM
mike1114's Avatar
Default Re: To those with 3" DP, bolt question. (Autoworks)
top two, OEM flywheel bolts.
Bottom two, studs and jam nuts (jam nuts are thin)
Old Apr 3, 2007 | 06:46 AM
BDogggUT34's Avatar
Default Re: To those with 3" DP, bolt question. (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">top two, OEM flywheel bolts.
Bottom two, studs and jam nuts (jam nuts are thin)</TD></TR></TABLE>
hmm, jam nuts. They stock these at any autozone and such i would assume right. Never heard of them.
Old Apr 3, 2007 | 07:22 AM
99B16Si's Avatar
i think u mean clutch bolts
Old Apr 3, 2007 | 07:25 AM
BDogggUT34's Avatar
Default Re: To those with 3" DP, bolt question. (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">
i think u mean clutch bolts </TD></TR></TABLE>
whats different about these if anything? smaller head or what?
Old Apr 3, 2007 | 07:36 AM
Running925's Avatar
just go to the local hardware store and pick up some allen head bolts. They are only gonna be a few cents each. and then u'll have much more room between the head fo the bolt and the pipe.
Old Apr 3, 2007 | 07:40 AM
boostedcivicsir's Avatar
Mr. Badwrench
you mean 10mm 12 pt clutch cover bolts. as do i
Old Apr 3, 2007 | 07:41 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 &raquo;</TD></TR><TR><TD CLASS="quote">
whats different about these if anything? smaller head or what?</TD></TR></TABLE>
yes, a regular 8mm x 1.25 or 1.5 has atleast a 12mm or more commonly a 13mm head. the clutch cover bolts are the same pitch and have a smaller 10mm 12 point head.
rico892002
Aug 2, 2012 07:26 AM
leroy12
Feb 12, 2010 12:41 PM
victor.m
16
Mar 13, 2008 05:51 PM
mrrugsr
Mar 1, 2006 08:00 AM
austrian type-R
Apr 19, 2002 07:56 AM
