fuel pressure help.
Old Apr 3, 2007 | 04:29 PM
imskatencrzy's Avatar
Default fuel pressure help.
i have a ls/vtec setup with a t3/t4 turbo. im running 7 psi. for some reason my car is running super rich and i cant figure it out. for fuel i bought a walbro 255lph pump and a cartech fmu(rising rate regulator). my **** is soo rich that when my car is warmed up my air/fuel meter is pegged all the way rich. only after i spool the turbo and let off the gas completely does it lean out. and only then it reads about optimal. the gauge is wired into my ecu so its not getting a faulty message. i need some help. i have adjusted the fmu all over the place but it only changed things after atmospheric. any help? thanks.
Old Apr 3, 2007 | 05:01 PM
Monstah's Avatar
what else are you using?
injector size?
current fuel psi at idle, wot?
system you're using to tune with?
imskatencrzy
Apr 4, 2007 03:42 AM
cnlevo
Aug 2, 2006 04:28 PM
onesikcivic
Jun 19, 2005 04:25 PM
bluesi00
Sep 7, 2004 10:20 PM
Johnyquest
Dec 29, 2002 03:26 PM
