b20 most boost
Well it really depends on what turbo is being used....
13lbs on a 14b turbo is ALOT different then 13lbs on say a SC61..
The only problem I seen with boosted B20 engines is that the sleeves are alittle to thin for high horsepower applications.
Its less about psi and more about power. You will get different power levels at different psi depending on the turbo...people will argue 8psi is 8psi all day but what matters is the quality of that 8psi charge. The efficiency of the turbo make a cooler denser 8psi with a greater oxygen content and its ability to draw out exhaust gasses is what counts much more than a "psi" number. People may argue with me but properly tuned the block will handle 300-400hp.
To the OP: If you're looking for 500whp, get an B18a/b/c and build a simple piston/rod combo. You wont have to sleeve for that power goals; whereas, on a B20, you'll be lucky to break 350whp without sleeving
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">300whp~ is about where id stop on a stock b20</TD></TR></TABLE>
best answer in the whole thread....
