intsalling cams.....cam timing
Old Aug 12, 2004 | 09:23 AM
boosted k20's Avatar
Default intsalling cams.....cam timing
oki guys, i just ordered all my parts to do my cams and timing belt install (recieved the Crower valve springs and retainers already, Honda Timing Belt, Honda water pump. Im still waiting on the Crower cams which should be here by next week along with the Skunk2 cam gears)
whats the basic setup for the cam gears for both the intake and exhaust cam. I know i will have to get it dyno tuned to get the most power, but im probably gonna dyno tune it a month after the install.
i've looked around and most people advance the intake about 4 degrees and retard the exhaust about 1 to 2 degrees. I just wanna know if anyone has adjustable cams in their car and what settings they used.
Thanks
Old Aug 12, 2004 | 10:02 AM
FlipSkater
Guest
Posts: n/a
Default Re: intsalling cams.....cam timing (boosted k20)
bump...i also like to know how to time cams
Old Aug 12, 2004 | 12:33 PM
anyone
Old Aug 12, 2004 | 01:35 PM
Padawan's Avatar
Darth ModerVader
Set both cams to 0° until you have them tuned on the dyno. The settings that worked on one motor won't necessarily work well on another.
Old Aug 12, 2004 | 02:21 PM
vtec69's Avatar
Default Re: intsalling cams.....cam timing (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Set both cams to 0° until you have them tuned on the dyno. The settings that worked on one motor won't necessarily work well on another. </TD></TR></TABLE>
my word exactly
Old Aug 12, 2004 | 03:39 PM
FlipSkater
Guest
Posts: n/a
Default Re: intsalling cams.....cam timing (vtec69)
how do you set them yank them or what
Old Aug 12, 2004 | 04:20 PM
Padawan's Avatar
Darth ModerVader
Default Re: intsalling cams.....cam timing (FlipSkater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlipSkater &raquo;</TD></TR><TR><TD CLASS="quote">how do you set them yank them or what</TD></TR></TABLE>
First, you need adjustable cam sprockets. I prefer to have a junk valve cover with the end cut-off to use for tuning at the dyno. This allows access to the sprockets so the timing can be adjusted, but doesn't require hacking up the stock valve cover.
As for the actual adjustment, you loosen the adjustment bolts on the sprockets (and remove the locking pin if you're using the ST Corsa sprockets that I prefer & recommend), then rotate the cam to the desired setting. After you reach the setting you want, simply tighten the bolts (and reinstall the locking pin).
When the tuning is finished, the stock uncut cover can be reinstalled, and the sprockets and timing belt are completely protected.
Old Aug 12, 2004 | 05:28 PM
FlipSkater
Guest
Posts: n/a
thanks you
wicked_b16eg
Dec 27, 2007 06:05 PM
foxone64
Nov 8, 2005 05:01 PM
216.226.142.95:27016
Jun 5, 2003 11:18 AM
acatak
Jan 28, 2003 05:29 PM
SCsol
Apr 21, 2002 09:34 PM
