ls vtec leaking
Old Aug 12, 2004 | 08:15 AM
room room's Avatar
Default ls vtec leaking
anyone have any problem with the cam seal that is leaking? on my lsv it wont stop leaking from the camshaft seal where the cam gears are. i change the saels twice and it wont stop. any ideas why it wont stop?
Old Aug 12, 2004 | 08:50 AM
CA6VTEC's Avatar
Default Re: ls vtec leaking (room room)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by room room &raquo;</TD></TR><TR><TD CLASS="quote">anyone have any problem with the cam seal that is leaking? on my lsv it wont stop leaking from the camshaft seal where the cam gears are. i change the saels twice and it wont stop. any ideas why it wont stop?</TD></TR></TABLE>
<FONT COLOR="royalblue"> Did you use Bond when u installed them?</FONT>
Old Aug 12, 2004 | 09:33 AM
boosted k20's Avatar
Default Re: ls vtec leaking (CA6VTEC)
yea did u use any bond on top of the cam cap at both ends? maybe u forgot that. It makes the valve cover not sealed properly if u forgot to put the honda bond. i didnt have any honda bond so i used gasket maker instead. i think u sed too much, u can see it in this picture. It's orange in color and it's at the ends of my valve cover on the left side
Old Aug 12, 2004 | 11:19 AM
Stewie's Avatar
Default Re: ls vtec leaking (boosted k20)
dude, where's the vtec? lol According to helms, you aren't suppose to use any kind of sealant on those seals. You are only suppose to put rtv on the underside of the cam caps that go over the seals.
I would say next time you install them, make sure you clean the cam cap and the seat for that seal with acetone and make sure it's free from any oil.
Old Aug 12, 2004 | 11:29 AM
au-gsr's Avatar
Default Re: ls vtec leaking (Stewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewie &raquo;</TD></TR><TR><TD CLASS="quote">dude, where's the vtec? lol According to helms, you aren't suppose to use any kind of sealant on those seals. You are only suppose to put rtv on the underside of the cam caps that go over the seals.</TD></TR></TABLE>
Ask any acura or honda technician and they will tell you to throw honda-bond all over the cam seal. experience wins over a manual, they did update the seal, but even the updated seal will eventually leak.
Old Aug 12, 2004 | 10:57 PM
room room's Avatar
Default Re: ls vtec leaking (au-gsr)
it is not the cam cap that im having problems with is the other side where the cam gears are. under the valve cover when the car is at idle it slowy leak and starts to drop and when you run it it spin to the cam gear and its all over the motor.
Old Aug 12, 2004 | 10:58 PM
room room's Avatar
thank for the help
Old Aug 13, 2004 | 08:52 PM
sleeperek's Avatar
Put honda bond on it.....These things are the best sealants ever made....I gurantee it will stop the leak...
Old Aug 22, 2004 | 02:51 PM
HICOMPCRX's Avatar
You may have a scratch or nick on the cam end where the seal rides on. Also put the seal on dry, the OEM seals have a lube on the inside lip, but the outside of seal should be dry.
elitetuning
Nov 28, 2005 07:34 PM
CrX-To-Tha-Max-v2.0
Sep 2, 2005 08:25 PM
vtec69
Jan 10, 2003 05:31 PM
vtec69
Jan 10, 2003 05:28 PM
vtec69
Jan 10, 2003 04:56 PM
