88 Teg ECU code
Old Aug 11, 2004 | 12:57 PM
MooreBoost's Avatar
Default 88 Teg ECU code
My 88 Integra ECU is blinking non stop, with no decipherable (sp?) codes. Its running a turbo DOHC ZC on the hack. I have a one wire DSM o2 sensor hooked up to the stock engine harness. The CEL comes on intermitently, and goes off when I turn the car off, but the ECU does have memory. The CEL only comes on after a decent drive, and just with normal driving. Whats wrong?
Old Aug 11, 2004 | 09:19 PM
chrisnova's Avatar
Default Re: 88 Teg ECU code (tegunderpressure)
I had a code 9 on my 1989 Integra LS this May and it turned out it was the crank angle sensor, just as the manual said. Are you sure there is no discernable code?
Try to count the differences of short and long flashes. If you are sure there is no pattern, then I can't advise you other than to tell you what the manual says, "take it to the dealer." Bestof luck!
Old Aug 12, 2004 | 05:36 AM
MooreBoost's Avatar
Default Re: 88 Teg ECU code (chrisnova)
Nope, there cetaintly wasnt any codes, just flashing.
Anyway, its gone now.
progress
Apr 14, 2005 01:09 PM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
arw321
Jan 22, 2004 08:33 AM
ZCHF
Jun 15, 2003 09:47 AM
Cereal_Killer
Jan 23, 2002 04:58 AM
