guage problem.. im stumped
Old Aug 11, 2004 | 09:45 PM
kuja's Avatar
Default guage problem.. im stumped
hey guys, i have a problem w/ my stock gsr guage cluster. Well.. they don't work, temp, tach, speedo, gas, odo, are dead. Everything lights, plugs are tight.. Heres another thing, along w/ those guages being dead, theres certain lights that are out. My ebrake light doesn't come on, gas light, maint light, hatch light etc. My blinker lights, high beam light all work. Im really stumped. Fuses are fine .. Im going insane, anyone have any ideas?? I bought a small cheezy tach and hooked it to the tach signal wire for now, so i have SOME idea how fast im going, and that works. So its not the signal.
Any help apreciated.
Thanks
Old Aug 12, 2004 | 07:20 PM
integlude's Avatar
Default Re: guage problem.. im stumped (kuja)
bump
Old Aug 12, 2004 | 07:31 PM
boosted k20's Avatar
hmmmm i would remove the cluster to check to see if the plug with all the wires on the back of it came loose.
Old Aug 12, 2004 | 08:25 PM
SYTFU Tommy.'s Avatar
Default Re: guage problem.. im stumped (boosted k20)
might be the vechicle speed senor(vss)...having same problem with my sister's accord. the funny thing was it was working for like a while today after like 1 week of it not working. after turning off the car, it doesnt work no more. i cant figure out wat the hech is going on
Old Aug 12, 2004 | 09:38 PM
kuja's Avatar
yea i checked all the plugs . if it was the vss wouldn't my gas and temp guages work
also another wierd thing is my rear defrost doesn't work either.. these all must tie in somewhere.... ugh, why..
Old Aug 12, 2004 | 09:56 PM
jdm_cars's Avatar
Electrical problem.
BTW, I have an extra GSR gauge cluster if you need one.
Old Aug 12, 2004 | 10:14 PM
shorto85's Avatar
Check to make sure that everything is grounded correctly.
Old Aug 12, 2004 | 10:25 PM
BoostedVtecGsr's Avatar
check all your GROUNDS.... make sure your car is getting enough ground power. check the ground from your tranny, i believe there are 4 ground wires.. some one correct me if im wrong.
SLOENUF
Jul 21, 2010 04:29 PM
SLOENUF
Apr 30, 2010 09:30 PM
Mr.Blondie
Jul 30, 2007 01:20 PM
