Knock Sensor Help!
Old Aug 10, 2004 | 02:24 AM
sQwiReL bOi
Guest
Posts: n/a
Default Knock Sensor Help!
i accidentally broke my knock sensor and i replaced it. but for some reason im still gettin a code 23. i checked if it was tight... i also disconnected the batt... i also tried to use a p28 wit obd2 to obd1 jumper and im still gettin code 23. dont know wat to do and i wanna go to the track on wed.
Old Aug 10, 2004 | 04:44 PM
sQwiReL bOi
Guest
Posts: n/a
bump!
Old Aug 10, 2004 | 08:21 PM
stumpyf4's Avatar
Default Re: Knock Sensor Help! (sQwiReL bOi)
Check the resistance of the wire from sensor to ECU. This wire is shielded too so any interferance or wire breakge will probably pop a code. Also can back probe the knock sensor signal with a ocilloscope and make sure it's a periodic wave form.
Old Aug 11, 2004 | 12:42 AM
Trac226's Avatar
Default Re: Knock Sensor Help! (stumpyf4)
Check the pin inside the connector. I've switched to an obd1 p28 and it's fine w/o a knock sensor.
thebleek
Jul 30, 2008 08:20 PM
ek4 sir civic
Jun 23, 2007 06:02 PM
92HatchB16
Oct 1, 2005 05:05 PM
ddong2lee
Mar 4, 2004 05:06 AM
Phaze2 Mike
Dec 30, 2002 04:10 PM
