brake problems
Old Aug 12, 2004 | 10:26 AM
sleepinbeauTEG's Avatar
Default brake problems
umm yeah i have a 90ls with a 94 ls engine in it. lately my brake pedal has been sinkin to the floor. i checked the brake fluid and i had none in there. and also there was a little green wire going into the master cylinder that was unplugged. i plugged it back in and filled it up again. the brake pedal was tight for a few miles then went all the way to the floor again. any suggestions? i would think replacing the master cylinder but that could be costly. so i was gonna see what you all would have to say first. thanks a lot.
Old Aug 12, 2004 | 10:54 AM
skunk2eg's Avatar
Default Re: brake problems (sleepinbeauTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepinbeauTEG &raquo;</TD></TR><TR><TD CLASS="quote"> i checked the brake fluid and i had none in there. </TD></TR></TABLE>
sounds like you have air in the line, be sure to bleed the line thoroughly(you will know when a solid stream comes out) and be sure to NOT let it get below the fill marker
98integralsB18
Suspension & Brakes
Mar 8, 2012 10:17 AM
Markb16a
11
Aug 26, 2010 09:12 AM
b18b1ef8
Apr 18, 2008 05:31 AM
spintboy
17
Jan 3, 2008 08:49 AM
The_In_Kid
Jul 7, 2002 11:45 PM
