kill switch problem
Old Aug 10, 2004 | 11:55 PM
l4 soldier's Avatar
Default kill switch problem
from what i understand the ecu is supposed to learn the way u drive or something?? so i'm thinking that whenever i take out my kill switch and put it back in, i'm resetting my ecu cuz all the presets on the radio station change and the clock goes back to 12:00. is that bad since the ecu doesnt get a chance to learn my driving
Old Aug 11, 2004 | 09:41 AM
l4 soldier's Avatar
Default Re: kill switch problem (l4 soldier)
bump
Old Aug 11, 2004 | 09:46 AM
l4 soldier's Avatar
help
Old Aug 11, 2004 | 09:59 AM
SynTeg's Avatar
I don't think Integras "learn" your driving.
Old Aug 11, 2004 | 10:05 AM
Ceres's Avatar
I think your ECU learned that you can't drive and it hates you now, so thats why it did that.
Old Aug 11, 2004 | 10:22 AM
l4 soldier's Avatar
Default Re: (SynTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg &raquo;</TD></TR><TR><TD CLASS="quote">I don't think Integras "learn" your driving.</TD></TR></TABLE>
well if you're not able to understand, the ecu gathers info from many sensors and it compiles the info together to come up with the lowest emissions and the best mileage. and this information is gathered as it adapts to the driving conditions which the driver places it into. therefore that's how it learns how u drive.
Old Aug 11, 2004 | 10:25 AM
tommymoose's Avatar
Default Re: (l4 soldier)
dont worry about it... for one reason or another people disconnect their negative battery terminal which resets the ecu all the time. Just make sure to let the car sit and idle for a few minutes before you go drive it.
Old Aug 11, 2004 | 10:32 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (tommymoose)
obd1 ecu's should be left alone for 15 minutes with NO touching of the throttle after being re-installed.
Old Aug 11, 2004 | 03:55 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: (PlastikOwl)
what kind of "kill switch" do you have that you take out and put back in every time?
Old Aug 11, 2004 | 04:03 PM
milton's Avatar
Default Re: (dLo GS-RaArRrRrRRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GS-RaArRrRrRRRR &raquo;</TD></TR><TR><TD CLASS="quote">what kind of "kill switch" do you have that you take out and put back in every time?</TD></TR></TABLE>
I think its his way of securing his vehicle? You take out the fuse at night? Is that what you do? My friend does this all the time.
Honda Hick's Avatar
You shouldn't have wired the kill switch up the way you did. It looks like you are cutting the power to the whole car. Do something simpler like cut the fuel pump power.
Old Aug 11, 2004 | 04:23 PM
IVI's Avatar
IVI
Default Re: kill switch problem (Honda Hick)
hondas do not have this problem where resetting the ecu will 'forget' everything it has 'learned'
i know that mitsubishi's have this as a common problem. when resetting the ecu will make the car run horribly for a good few minutes until the ecu can re-learn all the settings and adjust to run the car normally again.
this is done im told because your car changes, the carbon deposits, motor gets old, things change. and the factory ecu setting in those cars is set for a NEW engine right out of the dealer, and when the comptuer tries to run an old motor at new settings it wont run right until the ecu adjusts the neccesary things.
alot of people that get batteries replaced run into this problem where they think the mechanic ruined the car hwile replacing the battery.
Old Aug 11, 2004 | 06:01 PM
l4 soldier's Avatar
Default Re: (milton)
umm i dunno i bought it like that, the kill switch cuts off all the power i think. the lights or anything else will not work, nor will my keyless entry. so yea no power at all wen i take out the switch. so i should just let it run for like 15 mins every time i put it back in? man that'll be a bitch i take it out since i basically live in the hood, dont want it jacked.
Old Aug 11, 2004 | 07:37 PM
boosted k20's Avatar
what u need to do is "kill" that kill switch. Just run a switch to cut off the power to the starter, the igniton, or the fuel pump. it's very easy to do. the wires for the igniton and starter can be found right on the ingition key switch/steering wheel column. Do this so that all power to your car wont be killed
Old Aug 11, 2004 | 08:09 PM
Default Re: (boosted k20)
im asking, WHAT is this "switch"? if you have to take it out, then i'm assuming its a fuse or something. that's a pretty ghetto method..
a real kill "switch" is wired to some component in your car that prevents startup (i.e. the fuel pump in most cases) and is an actual switch that you flip on and off in the car, and doesn't usually interfere with power and such.
Old Aug 11, 2004 | 09:35 PM
mousiex113's Avatar
"and doesn't usually interfere with power and such."
well actually. Kill switches can be made for Electrical, Fuel Pump, and Starter. anything you name it. you can hook anything in ur car to a switch.
Old Aug 11, 2004 | 10:19 PM
Default Re: (mousiex113)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mousiex113 &raquo;</TD></TR><TR><TD CLASS="quote">"and doesn't usually interfere with power and such."
that's why i said "usually", because typically the kill switches people DIY are for the fuel pump or ignition.
Old Aug 12, 2004 | 02:12 PM
l4 soldier's Avatar
no my kill switch isnt ghetto. it looks like a little switch thats in the car. u take out the switch/key or watever and it kills the car. ill try to get someone to re-wire it since i know jack **** about it
pimpdd101
Mar 5, 2009 07:46 AM
EG6LS
Jun 1, 2006 05:50 AM
b16greenmachine
15
Mar 7, 2006 05:10 PM
91civichatchCrX
Jan 26, 2006 09:14 PM
eLeCtRoNSi00
Apr 16, 2004 01:17 AM
