blinker not working
Old Aug 11, 2004 | 06:31 AM
jdm_junkie's Avatar
Default blinker not working
i got into a accident about two weeks ago and my turn signal bulbs got crushed, then my rear blinkers worked for about three days but were blinking very fast then they just stopped period is this like a safty precaution from honda so it makes you get ur blinkers changed and how do i get them to work i know there is power goin to the new bulbs bc my turn signal lamps work just not the turn signal its self. so if i fix it do i just need to reset the ecu. someone please help cops at school are starting to harass me for this
Old Aug 11, 2004 | 08:01 AM
Quiks66's Avatar
Default Re: blinker not working (jdm_junkie)
Unless you altered your turn signal blinkers to do so all the time, your turn signals will blink rapidly if a bulb on the the affected side is blown or not functioning correctly. The blown bulb makes the non-blown bulb blink rapidly, letting you know that there is something wrong. Resetting the ECU won't do anything so don't waste your time. Check the wiring and status of bulbs to find your problem.
Old Aug 11, 2004 | 08:25 AM
92integra_gs's Avatar
i would check the bulbs.. then the fuse for the blinkers and then check the relay...
Old Aug 11, 2004 | 04:32 PM
jdm_junkie's Avatar
but my hazards work
Old Aug 11, 2004 | 04:44 PM
purplegsr's Avatar
If your turn signals were blinking fast after the accident repairs, it is possible that they reversed the wires when they plugged the lights back in. This would have caused your corner lights to stay lit at night (pretty bright) all of the time, and your blinkers wouldn't have been visible at night, but they would have appeared to work (but blink fast) from the interior of the car.
However, reversing the wires probably caused the bulbs to be on more than usual, and made one of the filaments in the bulb burn out. So, get new bulbs and reverse the wires going into the little clip (there should be 2 wires - just swap them and see what happens).
Sorry if that's confusing, PM me for clarification.
Old Aug 12, 2004 | 06:08 AM
jdm_junkie's Avatar
Default Re: blinker not working (purplegsr)
alright ive replaced all bulbs the lamps work
when i press the hazard button the front blinkers work but when i press the turn signal thing the turn signals do not work so i know the bulbs are working
Old Aug 12, 2004 | 07:07 AM
jweezy225's Avatar
its most likely messed up wiring, try checking under the bumper where the corner lens wiring is and see if anything is disconnected.
Old Aug 12, 2004 | 06:09 PM
jdm_junkie's Avatar
Default Re: blinker not working (jweezy225)
fixed it, it was a fuse lol i feel stupid
TimVanScyoc
Mar 31, 2017 03:22 AM
Bambooseven
Mar 3, 2009 08:40 PM
RemoveGiantWingOnYourCar
Nov 2, 2006 06:13 PM
SpoonFedHatch
Jul 11, 2004 09:40 PM
mike5809
Dec 17, 2003 05:16 PM
