engine swap question
Old Aug 11, 2004 | 11:01 AM
01Ntegra's Avatar
Default engine swap question
my friends brother in law has a 90-93 (not sure which year) prelude 2.0si just sittin there in his driveway. I was thinkin about buyin it and just takin the engine and working on that and droppin it my integra sometime in the future. I was wondering if that swap would be worth n n what are the engine codes for that prelude and my 01 integra ls
Old Aug 11, 2004 | 12:21 PM
ApexOne's Avatar
Default Re: engine swap question (01Ntegra)
Prelude motor swaps are definate good ideas only if it has an h22, then the swap would be and awsome start. I wouldnt recomend putting any other type of prelude motor in your car though. It would probably be cheaper to start with dropping a b16 head on your ls block. If you can get a si, or gsr tranny, it wouldnt hurt throwing one on while your under the hood. I have a 99 si. I put on a b18b1 under my head, changed the tranny to gsr with a lsd quife and an integra ls 5th. I ran on that for a while and gave a lot of people a run for their money. I recently did an H22 swap in an 96 hatch, and that was a little work, because of the way the shift linkage is. It actually changes over to cable linkages, so it involves a little welding and some exahust work. You will be doing the same thing if you plan on changing motors out. There are a few other things you are going to have to buy (Obviously) when you do the swap. You are off to a good start, but its really not a great idea. I cant help you with any of the engine codes, because i am unsure what your looking for.
chrisK20
Feb 3, 2015 12:14 PM
KleenKrew
Aug 28, 2010 10:37 PM
munky_350
May 10, 2008 11:01 PM
7808
Aug 29, 2003 04:12 AM
bluespecv
May 30, 2002 07:05 PM
