Rough Starting..
Old Dec 15, 2007 | 07:23 AM
ac_attak's Avatar
Default Rough Starting..
In the mornings my gsr has been having trouble starting. It turns over like 25 times before it starts, it stutter starts a couple times before it will final stay running. Also, a couple times it has started and then it will shut off on its own after a few seconds. It has new plugs, wires, dist. cap and rotor, fuel filter and battery but it still does it. Any ideas what else it could be?
Old Dec 15, 2007 | 07:35 AM
1Point8DC2's Avatar
Default Re: Rough Starting.. (ac_attak)
have you checked ignition timing? My gsr has a little trouble when its cold. I turn the key to on and let the fuel pump prime all the way and it usually fires right up.
Old Dec 15, 2007 | 07:40 AM
ac_attak's Avatar
Oh and it cranks a lot slower then normal in the mornings as well. Maybe its just the colder weather? But none of the other cars i own/have owned have done this though. It has been around 25 F in the morning lately.
Old Dec 15, 2007 | 07:41 AM
Dogginator's Avatar
Daisy... Daisy...
How does this car idle?
Old Dec 15, 2007 | 07:43 AM
ac_attak's Avatar
Default Re: Rough Starting.. (1Point8DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Point8DC2 &raquo;</TD></TR><TR><TD CLASS="quote">have you checked ignition timing? My gsr has a little trouble when its cold. I turn the key to on and let the fuel pump prime all the way and it usually fires right up. </TD></TR></TABLE>
K i'll try doing that from now on. I just don't understand why it sometimes shuts off after it has started though.. Whenever that has happened, it will start right back up like normal.
Old Dec 15, 2007 | 07:44 AM
1Point8DC2's Avatar
It's def. the colder weather causing the slower cranking. it still shouldn't take that long for your car to start.
ac_attak's Avatar
Default Re: Rough Starting.. (Dogginator)
Idle is perfect.
Old Dec 15, 2007 | 12:18 PM
ac_attak's Avatar
Do you guys think they will take the battery back because of this? I know there is a 5 year warranty on it and its probably a year old. Maybe if i exchangeed it for an optima battery or something it would work better..
attz0r
Feb 15, 2014 04:03 PM
mouab18c1
Jan 22, 2011 07:38 PM
johnny090881
Jun 7, 2009 10:56 PM
thebigone
Mar 21, 2009 04:00 PM
dohctor_B
Jul 22, 2007 09:41 PM
