Check Engine Light question!!
Old Dec 12, 2007 | 09:18 PM
91b16acrx's Avatar
Default Check Engine Light question!!
I have a 98 integra gsr. My check engine light has been blinking on and off while im driving. Anybody know what this means?
Old Dec 13, 2007 | 03:53 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Check Engine Light question!! (91b16acrx)
Pull the codes. Look at the FAQ thread for instructions.
Old Dec 13, 2007 | 04:19 AM
AWD Terror's Avatar
Default Re: Check Engine Light question!! (Dogginator)
It means you need to "check your engine"
Old Dec 13, 2007 | 07:06 AM
JDMFantasy2k's Avatar
Default Re: Check Engine Light question!! (AWD Terror)
if you check engine light is bliking, you shouldn't drive it. A blinking CEL indicates a type A misfire which can cause severe damage to the catalytic converter and even the engine. You got something serious going on.
Old Dec 13, 2007 | 07:42 AM
GSR-TRBO-DA's Avatar
does it come on for a while, then go off for a while? or is it blinking? if it is a chipped ecu, i don't know if it has a (KAM) keep alive memory. if its factory, you should still be able to pull a code that is in the memory. that is if it isn't ON at that particular time.
Old Apr 20, 2008 | 08:00 AM
rjl7405's Avatar
Default Re: Check Engine Light question!! (GSR-TRBO-DA)
Hey guys,
I have an 89 Integra LS and a check engine light problem. When I turn the key to start, the check engine light rapidly flashes at a constant speed and doesnt stop. The car seems like it wants to turn over, but it wont. The light on the ECU also rapidly flashes. Can anyone help? Thanks!
Old Apr 20, 2008 | 08:12 AM
xbabysharkx's Avatar
Default Re: Check Engine Light question!! (rjl7405)
check your battery, it sounds like its dead.
Old Apr 20, 2008 | 08:39 AM
rjl7405's Avatar
Default Re: Check Engine Light question!! (xbabysharkx)
I just had a friend of mine yesterday jump my car because I noticed that the battery was a little weak. Do you think that the battery is completely dead, whereas I need to get a new one? Could there be any other reasons the ECU and check engine light is doing this?
Old Apr 20, 2008 | 09:20 AM
kelviiv's Avatar
your battery
keegur
Acura TSX
Jan 10, 2009 01:33 PM
SlammedBlackGSR
Nov 20, 2006 02:04 PM
jdm82
Mar 7, 2006 01:08 PM
98teg
Oct 6, 2003 07:39 PM
ex_crxer
Apr 6, 2002 07:54 AM
