dash problems
Old Dec 13, 2007 | 05:18 PM
tweek_boii's Avatar
Default dash problems
i have a 95 acura integra gs-rl and my gauge dash does not light up
the little lines light up and the mileage does light up but the circle does ot light up
any one have quick fix?
Old Dec 13, 2007 | 05:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: dash problems (tweek_boii)
The bulbs could be burned out. Pull the cluster and changed them. Remove the screws from the trim ring, then the screws holding the cluster.
Old Dec 13, 2007 | 05:25 PM
tweek_boii's Avatar
Default Re: dash problems (Dogginator)
oh i did that i took out the whole thing and looked
i couldnt pull the whole thing out but every thing seems to be connected , with the key switch i manged to turn it on but if only for a lil while and then nothing
it lighted up bright blue or bright white. i need ESPECIALLY for night, i took it to mechanic but he says everything is fine and he doesnt to technical
Old Dec 13, 2007 | 05:35 PM
Dogginator's Avatar
Daisy... Daisy...
You can easily disconnect the three plugs in the back and completely remove it. The bulbs are located in twist out sockets on the back of the cluster.
Old Dec 13, 2007 | 05:43 PM
tweek_boii's Avatar
I WILL TRY THAT TOMMOROW
BUT I NEVER TOOK THE BULBS OUT...
I DONT KNOW IF IT IS OK FOR ME TO POST PICTURE OR I WOULD SHOW YOU EXACTLY WHAT IM TALKING ABOUT
THE RPM CIRCLE THE SPEED CIRCLE THE HEAT CIRCLE THE FUEL CIRCLE,
THEY ALL DONT LIGHT UP
IN DAYLIGHT THEY ARE WHITE
Old Dec 13, 2007 | 05:44 PM
Dogginator's Avatar
Daisy... Daisy...
You can post a picture. There are instructions here:
https://honda-tech.com/zerothread/586924
Old Dec 13, 2007 | 05:49 PM
tweek_boii's Avatar
SEE WHATS WHITE, IT DOESNT LITE UP AT NIGHT
Old Dec 13, 2007 | 06:05 PM
Dogginator's Avatar
Daisy... Daisy...
The whole face should not illuminate, just the lines, numbers and needles. You have aftermarket faces.
Old Dec 13, 2007 | 08:11 PM
tweek_boii's Avatar
OH ..SO PRETTY MUCH THE ONES I HAVE JUST WILL BE HARDER TO FIX... OR REPLACE
I HAVE LIKE THE SADDEST QUESTION..CAN YOU PUT A 99+ INTEGRA FRONT BUMPER ON A 95 db8 ?
Old Dec 14, 2007 | 03:49 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweek_boii &raquo;</TD></TR><TR><TD CLASS="quote">OH ..SO PRETTY MUCH THE ONES I HAVE JUST WILL BE HARDER TO FIX... OR REPLACE
I HAVE LIKE THE SADDEST QUESTION..CAN YOU PUT A 99+ INTEGRA FRONT BUMPER ON A 95 db8 ?</TD></TR></TABLE>
Yes. See the FAQ thread.
Old Dec 14, 2007 | 04:12 AM
Blahblah718293's Avatar
yes, 94-97 and 98-01 bumpers are interchanable WITH the headlights and blinkers. 2 door or 4 door doesnt matter.
as for the cluster. have you checked the fuse?
Andrewzabomb
Feb 21, 2012 12:32 PM
Riga89
Sep 23, 2007 02:17 PM
Blahblah718293
Feb 20, 2007 06:30 PM
PH3593A
Jul 20, 2004 10:03 AM
StockTeg
Nov 21, 2001 02:35 PM
