HELP: check engine o2 sensor
Old Dec 12, 2007 | 05:05 PM
drastikmeasurez's Avatar
Default HELP: check engine o2 sensor
heres my problem i have obd2 jdm gsr swap in a '00 gsr chasis.. using the usdm harness and usdm ecu.. my cars throwing the o2 sensor code.. changed both o2s and the check engine lights still on.. throwing the same code.. what might be my problem?
Old Dec 12, 2007 | 05:53 PM
dickdragon's Avatar
what code is it?
Old Dec 14, 2007 | 09:32 AM
Default Re: HELP: check engine o2 sensor (drastikmeasurez)
bump
Old Dec 14, 2007 | 09:36 AM
integra4eva's Avatar
ok this is not the answer to your problem, but its a sugestion if your an enviornentalist freak... just get a o2 sensor defuser, unscrew the sencor put this cylinder looking thing in it, so the sencor in not all the way in the pipe.. there fore it reads the carbon but not enough to give a code... u might want to do a lil bit more research with it, by buddy did it on his s2k and took off the cap..= more ooph
Old Dec 14, 2007 | 09:59 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: HELP: check engine o2 sensor (integra4eva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra4eva &raquo;</TD></TR><TR><TD CLASS="quote">ok this is not the answer to your problem, but its a sugestion if your an enviornentalist freak... just get a o2 sensor defuser, unscrew the sencor put this cylinder looking thing in it, so the sencor in not all the way in the pipe.. there fore it reads the carbon but not enough to give a code... u might want to do a lil bit more research with it, by buddy did it on his s2k and took off the cap..= more ooph</TD></TR></TABLE>
dude seriously learn to spell
Old Dec 14, 2007 | 12:53 PM
Default Re: HELP: check engine o2 sensor (GRAF-FITI)
Old Dec 14, 2007 | 01:05 PM
GSR-TRBO-DA's Avatar
what was the code open loop or closed loop. dude and they are called o2 sensors
cause all they read is oxygen.
Old Dec 14, 2007 | 02:33 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drastikmeasurez &raquo;</TD></TR><TR><TD CLASS="quote">heres my problem i have obd2 jdm gsr swap in a '00 gsr chasis.. using the usdm harness and usdm ecu.. my cars throwing the o2 sensor code.. changed both o2s and the check engine lights still on.. throwing the same code.. what might be my problem?</TD></TR></TABLE>
you reset the ecu after changing the sensors, right? if not, do that.
Old Dec 14, 2007 | 02:57 PM
1Point8DC2's Avatar
Default Re: HELP: check engine o2 sensor (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">
you reset the ecu after changing the sensors, right? if not, do that.</TD></TR></TABLE>
X2
Old Dec 14, 2007 | 10:35 PM
Default Re: HELP: check engine o2 sensor (1Point8DC2)
already tried that 50 billion times.. left it running for 30 mins.. reset it again.. still on..
Old Dec 15, 2007 | 12:01 PM
bump
Old Dec 15, 2007 | 01:33 PM
hatchling37's Avatar
Does it turn on immediately? If so, you have some issues with your wiring. It sounds to me like your ECU isn't recognizing that your sensors are there or hooked up.
Old Dec 15, 2007 | 01:40 PM
integravtec92's Avatar
look into your knock sensor.
Old Dec 15, 2007 | 01:54 PM
Dogginator's Avatar
Daisy... Daisy...
Go to a local auto parts and have them pull the codes. Post the P#### codes. They should pull the codes for free.
Old Dec 21, 2007 | 09:14 AM
what is the code? there at least 2 o2 sensors. did you have any other codes? cause they could be causing the o2 sensor to read to much air and that is why they through a CEL. check your codes and start with the lowest one and work your way up. it is a problem that is causing your car to go lean that is why your o2 sensors are saying what the fuQ? and throwing a code.
bignil4
Jan 2, 2012 03:40 PM
slim689
Apr 19, 2007 10:55 AM
Koyoloeor
Oct 13, 2005 04:57 PM
inzecure1
Mar 18, 2004 10:43 PM
89Si
Apr 21, 2002 07:24 PM
