Fuel Pump Help
We were attempting to install a fuel cutoff switch in my friends 96 integra. We cut the yellow/green wire and tried starting the car and it didnt work so it was the correct wire to cut.
So we spliced into the main wire and connected it to some 18 gauge wire that connected to the swtich. Before soldering the wire together, we tested it out and it worked.
After we soldered it together, the car wouldnt start anymore. So we took off the new wire and just connected the original wires back together, like how it was before. The car still would not start. So what is the problem? Could it be a fuse?
Any help would be appreciated, thanks.
fuel pump relay located under left side of dash test for continuity between relay terminals No.4 and 5. if continuity exists its ok if not needs new relay
carlos8
11
Oct 31, 2013 08:32 PM
97civic07gsxr
Jan 6, 2009 04:21 PM
hatchback_al
Oct 26, 2004 10:00 AM
