Timing advance for Boost?
Old Dec 14, 2007 | 11:13 PM
98GSR-Turbo's Avatar
Default Timing advance for Boost?
How many degrees would i want to advance my timing for 4 psi and then 9 psi? Im gonna daily drive it at 4 and when i need the power bump it to 9.
Old Dec 14, 2007 | 11:43 PM
mtber's Avatar
Default Re: Timing advance for Boost? (98GSR-Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSR-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">How many degrees would i want to advance my timing for 4 psi and then 9 psi? Im gonna daily drive it at 4 and when i need the power bump it to 9.</TD></TR></TABLE>
You would not want to advance your distributor ignition timing.
You need to read http://www.phearable.net/tech/....html
Get your self a engine management system & have the car dyno tuned
Old Dec 15, 2007 | 01:10 AM
kraig8's Avatar
before i got my hondata i used a MSD BTM to retard my ignition timing. i only pulled about half a degree per pound and i was running 8 psi.
Old Dec 15, 2007 | 06:19 AM
96 GSR-T's Avatar
lol, you got alot of reading to do dude..... seriously
Old Dec 15, 2007 | 07:31 AM
1Point8DC2's Avatar
https://honda-tech.com/zeroforum/16
look around in that forum..... just remember not everyones word is gospel.
Old Dec 15, 2007 | 10:55 AM
Default Re: Timing advance for Boost? (1Point8DC2)
Im not advancing my ignition. The cams is what im talking about. You know adjustable cams gears.
Old Dec 15, 2007 | 03:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSR-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Im not advancing my ignition. The cams is what im talking about. You know adjustable cams gears.</TD></TR></TABLE>
Adjustable cam gears must be tuned on a dyno. You cannot use anyone else's settings as every engine is differently and reacts differently to tuning.
Set both cam gears to the stock 0 setting until you get it on a dyno.
Old Dec 15, 2007 | 05:17 PM
Default Re: Timing advance for Boost? (PatrickGSR94)
i dont have axcess to a dyno. so what is another alternate thing to do?
Old Dec 15, 2007 | 06:09 PM
Blahblah718293's Avatar
what do you mean dont have access to a dyno, seach around for tuning shops in your area.
its not somthing you can do yourself. it takes ALOT of knowlege and experience to do it right.
Old Dec 16, 2007 | 05:45 PM
0bd1_Kanobe's Avatar
Default Re: Timing advance for Boost? (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean dont have access to a dyno, seach around for tuning shops in your area.
its not somthing you can do yourself. it takes ALOT of knowlege and experience to do it right.</TD></TR></TABLE>
WERD . I seen this so many times lol, do you have access to a butt dyno?
Old Dec 16, 2007 | 05:51 PM
96 GSR-T's Avatar
if you dont have access to a dyno, best thing to do is not touch them, aint nothing they can do that 1lb boost cant.
Old Dec 16, 2007 | 08:36 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">You cannot use anyone else's settings as every engine is differently and reacts differently to tuning.</TD></TR></TABLE>
Exactly, everyone tries to compare settings, maps, etc when every engine no matter how close the setup is going to be different in some aspect.
My advice, get it tuned correctly by a proffessional&lt;--- thats the key word. No offense to you personally
NLR
Sep 9, 2006 06:31 AM
The Jacko
Jun 22, 2005 12:07 PM
xcountrirunr
Dec 1, 2004 08:57 AM
Btothe3rdDegree
Nov 12, 2004 04:53 PM
CRXLST
Oct 27, 2004 09:45 PM
