obd0 injectors?
Old Dec 14, 2007 | 06:18 AM
Homotor's Avatar
Default obd0 injectors?
okay so i got an ls that is obd1 about to convert to obd0. would i have to get obd0 injectors also? (aside from changing the wire harness, ecu, and distributor) or will the ones i have in now which are obd1 is compatible? thanks in advance
Old Dec 14, 2007 | 06:20 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: obd0 injectors? (Homotor)
obd0 and obd1 are different
don't downgrade to obd0, obd1 is where it's at for tuning purposes
Old Dec 14, 2007 | 06:25 AM
Homotor's Avatar
Default Re: obd0 injectors? (GRAF-FITI)
i would keep it obd1 but the motor came out of my eg and is goin into a 91 teg... and im on a low low budget and i already have all parts for obd0 except for the injectors maybe later on in the future i'll change it to obd1 but i jus need something that will get me places(grocery getter)
Old Dec 14, 2007 | 06:27 AM
St Jimmy's Avatar
* B A N N E D *
OBD1 injectors have resitance built in.
OBD0 injectors utilize a resitor box because they arent built in.
If you take out the resistor box, OBD1 injectors will work fine.
And like graf said OBD0 sucks.
Old Dec 14, 2007 | 06:32 AM
Homotor's Avatar
Default Re: obd0 injectors? (St Jimmy)
i would really like to keep it obd1 i still have the wire harness distributor and ecu from when i pulled it out of my hatch but what changes would i have to make on the teg for it to be obd1?
Modified by Homotor at 7:42 AM 12/14/2007
Old Feb 16, 2008 | 08:40 AM
DA9lst's Avatar
Well... as far as I know.. U need ecu. Distributor and o2 sensor.. And you'll need to wire up some stuff by urself like the o2... u can buy harnesses for both ecu and distributor.. U can also use ur 91 injectors which are peak and hold compared to the obd1 which are saturated.. As long as u keep the resistor box in u can still run the obd0 injectors..
Dkahn18
Feb 18, 2009 04:41 PM
lilsicsoul
Jan 22, 2009 09:31 PM
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
91lsteg
May 15, 2005 11:32 AM
mengy007
Oct 28, 2004 09:38 AM
