Mildew smell
Old Dec 13, 2007 | 05:42 PM
I got a honda's Avatar
Default Mildew smell
i did a search and not much came up but i have that mildew smell in my dc4 and its starting to **** me off lol...will a simple febreze for autos take car of it??....let me know if you guys have any other suggestions please, thanx
Old Dec 13, 2007 | 06:04 PM
1Point8DC2's Avatar
Default Re: Mildew smell (I got a honda)
Did you check for active water leaks? Sounds like you have some old water laying somewhere. Check around. Check the trunk under the spare.. thats where i find the problem 80% of the time.
Old Dec 13, 2007 | 06:06 PM
Dogginator's Avatar
Daisy... Daisy...
You need to be more specific. Where is this smell: trunk, interior, heater?
Old Dec 13, 2007 | 06:32 PM
Default Re: Mildew smell (1Point8DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Point8DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Did you check for active water leaks? Sounds like you have some old water laying somewhere. Check around. Check the trunk under the spare.. thats where i find the problem 80% of the time.</TD></TR></TABLE>
hhmm yes there is some water in the trunk hahaha...i cant seem to find were its coming from....or were should i check if its in the trunk,i mean were are the usual leaks?...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">You need to be more specific. Where is this smell: trunk, interior, heater?</TD></TR></TABLE>
just the whole inside of the car period...
Old Dec 13, 2007 | 06:34 PM
Dogginator's Avatar
Daisy... Daisy...
The tailight gaskets are the usual water leaks for the trunk.
Old Dec 13, 2007 | 06:47 PM
Default Re: Mildew smell (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">The tailight gaskets are the usual water leaks for the trunk.</TD></TR></TABLE>
hmm any right way to check for leaks?..im guessing put a hose over the rear of the car and climb thru the back n check for any leaks?....thanx again
Old Dec 13, 2007 | 08:18 PM
Rikter's Avatar
To do it the "right" way.... take off all your interior rear panels then sit in teh trunk. Have a friend witha hose spray the back of hte car with the hatch closed. You should see whater coming in soon enough.
Another sure fire way to see that your tailight seals are gone is that you'll see condensation (or sometimes even a water level) inside the lens portion of your tailights.
Another thing to check is the seal around your hatch for cuts, rips, missing parts, etc.
-Rik
Old Dec 13, 2007 | 09:01 PM
CB's Avatar
CB
Default Re: (Rikter)
I also found a water water leak in my dc2 that I just picket up. However, the leak left an oder that I cannot get rid of! Its not daily driven and I tryed airing it out for weeks but nothing happened. Does anyone know of a product that would get rid of this smell?
Old Dec 13, 2007 | 09:40 PM
Dc2FaN's Avatar
I agree,just take your panels off sit in the trunk and have someone run a hose over the trunk or hatch etc... Also if the trunk liner is wet and you live in a humid area or a warm climant..I wouyld suggest that you take out the rear interior let it sit out in the sunin the grass or in your garge with some fans on the interior..I did this with my car after winter and i havent had a problem since.
Old Dec 14, 2007 | 03:47 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got a honda &raquo;</TD></TR><TR><TD CLASS="quote">
hmm any right way to check for leaks?..im guessing put a hose over the rear of the car and climb thru the back n check for any leaks?....thanx again</TD></TR></TABLE>
You can also tape paper towels in the trunk below the taillights, near the wheel wells, etc.
Old Dec 14, 2007 | 12:16 PM
EX PLCIT's Avatar
I had a mildew problem 10 times worse than yours in my teg so I can share some of the tricks I learned to salvage your interior.
GETTIING RID OF MILDEW INSIDE YOUR RIDE
1. You have to find the source of the leak and stop it, if you don't there is no point in continuing the rest of the process because it's just counter productive.
2. Thoroughly dry the all areas and surfaces that are still wet or damp .
3. Kill the existing mold/mildew. Sunlight will kill mildew so if you have any removable panels take them out, wipe them down and put them in the sun. Chlorine bleach will also kill it so use this diluted with water on all your hard surfaces, but be careful not to get bleach on your carpet or cloth seats or any type of dyed fabric or cloth.
Cleaning mildew from cloth seats and carpet will be the most work because you can't use bleach on these and they tend to hold the mildewy odor. There are some natural ways to deal with this but the ingredients may be hard to find or expensive. One such way is mixing grapfruit seed extract in a spray bottle with water, spraying it on the fabric and allow it to air dry. Another method is using white vinegar. Vinegar smells probably just as bad as the mildew does but the smell dissipates as it dries. If you have a carpet shampooer like a Bissel or something that has a hand attachment, you should try using straight vinegar as the cleaning solution and use it on your seats and carpet.
**Lysol** kills mildew too but with any of these things you should test a small spot first to make sure it won't ruin your fabric.
Well I hope someone can use this info to repair mildew damage because replacing your interior ain't exactly cheap.
Old Dec 14, 2007 | 05:51 PM
CB's Avatar
CB
Default Re: Mildew smell (EX PLCIT)
^^^^Thanks for the reply man, I'll try putting my panels in the sunlight when it gets warmer and see if that works.
Old Dec 15, 2007 | 02:03 PM
Default Re: Mildew smell (CB)
wow i actually did not expect all these replys..lol..thanx alot guys for the help and suggestions, i should be able to remove that damn smell now!
hondapower321
Dec 20, 2009 07:54 AM
dude_uuk
16
Jul 28, 2008 09:30 PM
vizions
Jul 30, 2005 02:29 PM
low430
May 18, 2005 10:34 PM
95GS-R
Dec 28, 2003 03:11 PM
