vtec problem
Old Dec 17, 2007 | 08:26 AM
pokmijn's Avatar
Default vtec problem
need help finding out what wrong my vtec lags in 2nd gear it dont engage until like 7.3 rpm. its only in 2nd gear.
Old Dec 17, 2007 | 08:43 AM
pokmijn's Avatar
Default Re: vtec problem (pokmijn)
any help......
Old Dec 17, 2007 | 02:22 PM
F Bomb's Avatar
check your oil level or oil pressure...
Old Dec 17, 2007 | 02:24 PM
Dogginator's Avatar
Daisy... Daisy...
Details? (Engine, ECU, OBD, CELs)
Old Dec 17, 2007 | 04:02 PM
pokmijn's Avatar
Default Re: vtec problem (Dogginator)
i have a 90 da with a jdm b16a and running on pr3 ecu. i check the oil, i let it warm up, i know vtec works. the problem only happen when i take 1st gear all the way then into 2nd gear thats when 2nd gear has no vtec until like 7.3 rpm but if i just floor it from second gear vtec engage normally.
Old Dec 21, 2007 | 02:35 PM
pokmijn's Avatar
any help.
Old Dec 21, 2007 | 03:12 PM
autox228's Avatar
check the gasket for vtec solenoid
Old Dec 21, 2007 | 06:13 PM
AW's Avatar
AW
Default Re: vtec problem (autox228)
Check both gasket screens in the vtec solenoid.
Old Dec 21, 2007 | 06:56 PM
Mr. DB2's Avatar
Check the oil pressure switch that on the spool valve of the vtec assembly.Check the screens in the vtec assembly gaskets.
Old Dec 27, 2007 | 07:27 AM
pokmijn's Avatar
all gasket are still good just replace them when i did the swap. how do i check for what code its throwing.
sorry for the slow response.....
bb_SI
11
Jun 26, 2008 06:13 PM
ALLmotorTYPES
48
Jan 30, 2007 10:02 PM
blackie
Nov 25, 2005 06:29 PM
goforbroke
Feb 24, 2003 04:47 PM
Teal95Coupe
Nov 25, 2001 06:29 PM
